First pictures of my E30
  • Mike325
    • Mar 2006
    • 3685
    Also, is this a timing belt or chain engine?
    Originally posted by Kershaw
    • THM3
      • Sep 2005
      • 230
      Entdecken Sie BMW Welt und BMW Museum, zwei der beliebtesten Sehenswürdigkeiten in München, mit Ausstellungen, Erlebniswelt und Fahrzeugauslieferung.
      There ya go.
      • euroshark
        • Apr 2006
        • 3491
        I do have to change the engine side of the C101 plug / fusebox plug. I just cut the plug off of the E30 engine harness, with about 6 inches of wire, and soldered. I made sure to check various pinout diagrams so I know what wire goes where, and not suprisingly, all of the wires are joined to wires of the same color! Good old BMWs... The M30 is a timing chain motor, and yes, the only new pieces required to fit the motor into the car were the www.e30.de motor mount brackets! After that though, there are a few pieces that are needed to complete the swap, like a radiator from an E28 or E24, and you might have to have your driveshaft shortened.
        I stuck the front half of my 6 series shaft on the rear half of my 3 series shaft, and its about 1 inch too long... So I guess I will see if there is a shorter front section that I can use, or just get mine cut down and balanced.
        • mtechnik
          • 6156
          glad for ya man
          • euroshark
            • Apr 2006
            • 3491
            Thanks for the comments guys!
            • 325iCabrio
              • Jun 2006
              • 485
              That's pretty sweet. I think if I ever had to swap engines, I'd pick the M30. But hopefully my M20 will keep chugging along.
              And hey, when people ask what you drive, you can say a 335i, and they'll think you've got that fancy twin-turbo job. :p
              1988 325ic Automatic
              • CleanAzzE30z
                • Jan 2004
                • 11794
                Explain what you did when you say "tinkered for a while". ;) Sorry if this has been addressed in the previous posts. Im lazy
                mariano
                • euroshark
                  • Apr 2006
                  • 3491
                  Well, tinkering sometimes involves beer... And maybe connecting some vacuum hoses that weren't connected by a dealership "mechanic". It seriously took about an hour and the thing started right up after 8 months of "diagnosis and work" by these retards! So to show my delight, I rented a hoist a few days later and ripped that anemic piece of shit out!
                  • euroshark
                    • Apr 2006
                    • 3491
                    Update:
                    Wiring is done, plumbing is done, car should start once I get some oil in it!
                    Got an E32 air box on the way, should clean up the engine bay nicely vs the old style air box...
                    Just waiting on the driveshaft now. Going to test fit the 6er's exhaust tomorrow, just the front half. Side by side with the e30 exhaust, it looks to be the exact same shape until right after the cat... We will see.
                    More pictures soon!!
                    • delphini
                      • Apr 2006
                      • 680
                      Kee Us Updated ......
                      :pimp:
                      • Simon S
                        • Oct 2004
                        • 3758
                        Originally posted by euroshark
                        It also runs 9.3:1 compression,
                        Originally posted by Widm3r
                        That car is dying for boost...
                        fuck yeah !
                        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                        • euroshark
                          • Apr 2006
                          • 3491
                          Here is a little bit of progress... Everything is wired and it runs! No exhaust yet, no driveshaft yet because the guy that I am swapping parts with doesn't answer his phone :p , and the E32 airbox is STILL in the mail apparently... but she's getting closer.
                          • SpunkyE30nOk
                            • Jun 2006
                            • 228
                            its looking real good...what engine position did you use? you started it up without the exhaust hooked up? how loud was that?
                            • euroshark
                              • Apr 2006
                              • 3491
                              I used engine position 2 on the Type I mounts. It sits pretty damn far back, the head actually touches the firewall insulation and part of the block had a tiny bit of interference on the drivers side. Without exhaust (just manifolds) it is god damn loud! But it sounds good, and very smooth (valve jobs are niiiiiiice).
                              Soon I will be building the exhaust, and probably having my 6 series driveshaft shortened because the guy who was supposed to give me a 325i auto front half seems to have flaked on me...
                              • nes85er
                                • Jul 2006
                                • 417
                                hey nice swap you got going on, i dont recall seeing an m30 swap done before...pretty kool, looks like its coming along nicely.
