Start on m50 or wait ?
  • Jean
    • 18228
    What would you guys do in my case ? I've done most of needed maint. already, it's got a 3.73 lsd in it now and rear brakes are now disc brakes.
    The next 3 large items I have planned are the following:
    m50 engine swap & e36 steering rack swap
    15x8 rota wheels
    bbk
    Would you go ahead and do wheels next to make room for the bbk or start finding all the components for the m50 swap ? I am thinking running rotas with bbk and m10 would be
    25
    wheels and/or bbk
    12.00%
    3
    m50 and then wheels and bbk
    28.00%
    7
    drift it into a curb r3v style
    60.00%
    15
    The poll is expired.
  • 325Projectz
    • Jan 2005
    • 1956
    make it a sleeper and go from there.
    91 m3
    • FredK
      • 14762
      Lookin good!
      If you want to do the M50 swap cheaply, I'd suggest sourcing the components slowly, as parts become available. Sometimes it's hard to find a 525i oil pan, and sometimes it's easy.
      • Widm3r
        • Jan 2006
        • 1129
        Start collecting parts for the m50 swap, if i were you i would wait on the bbk and get powerslots, ss lines, and pads. If you do a 5 lug swap you can upgrade to e36 M3 brakes, and have suffiecient braking power.
        Just my 2 cents,
        Brian
        • Jean
          • 18228
          Not doing 5 lug swap, and rotors will be solid. Pads probably hawk hp+ or carbotechs (if they have a set for our cars), as I've had good luck with both before.
          • golde30
            • 11464
            do the m50. you have great resources for e36 parts in rancho, go there for your e34 oil pan also. once the motor is in, build the car around it.
            IG: @Baye30
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              m50, check out my thread in the 24v section. have alot of the parts listed there
              • FredK
                • 14762
                I say stick with bottlecaps, and install an S50 instead of an M50.
                • backtrail69
                  • Jul 2005
                  • 4471
                  I would do wheels and any cosmetics then drop in a m52 or s50... M50s are BLA
                  :: PNW Crew ::
                  '87 325 4dr, '74 2002
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    voted.
                    91 m3
                    • KangamangusDriver
                      • Aug 2005
                      • 1870
                      No brainer
                      M50! Much more enjoyment and satisfaction from the swap!!!!!
                      • rede30
                        • 4697
                        just get some weaves on that beast to hold you over and rock a 24v.
                        • JeffNJM3
                          • Dec 2004
                          • 666
                          Drive it. I see its going to be your auto-x/track car. Learn the car how it is now, and then do the motor swap in the off-season(if there is such a thing in sunny cali!) Plus the 3.73 will be a little too much with the m50, you'd probably want a 3.25 or 3.46.
                          All Your Base Is Belongs To Us
                          • lordofmpower
                            • 153
                            M50 FTW. I wouldn't hesitate to run an M50 with a 3.73 if you are running a getrag 260. I'm running a 4.10 with my built M50 and a 260 and I love it 6500 gets me 137mph in 5th and when I finish my chip i'll let you know what 7500rpm gets me.
                            carbotech does make pads for these cars and they are hands down the best pads i have ever run. my suggestion is panther +'s they take a sec or 12 to get warm and squeal like a hord of dying babies but with sticky tires you can outbreak a most sportscars handsdown and I have set my caliper seals on fire before they ever showed signs of fade.
                            • Stu Mc
                              • 4083
                              It's hard to get brake fade on the street !
