Andy's E30 on SSR Comps w/ 235/40/17 Azenis
  • Andy
    • Nov 2005
    • 121
    Here’s my autox (STX) and track setup. I thought I’d share some info and pics in case anyone else wanted to run this setup.
    The wheels are 17x7.5 SSR Comps, ET37, 4x100. These wheels are fitted for the MINI Cooper S. I had to bore the aluminum centering ring 1mm (from 56.1mm to 57.1mm) and run a 12mm spacer on all 4 corners (along with 45mm lug bolts). The rear fenders are not rolled and so far no rubbing. The rear tires are pretty close to the rear fenders, so this weekend at the autox will be the true rub test. I could get away with running a smaller spacer in the rear, I’d prefer to not roll the rear fenders, however this too would do the trick.
    As far as suspension goes, I’m running IE Stage 3 Race Springs, Koni S/A shocks, and ST sway bars. –2.5 degrees of camber and 0 toe in the front and –2.0 degrees of camber and 1/8” toe-in in the rear.
    The tires are 235/40/17 Falken Azenis RT 615s.
    EDIT: These wheels and tires are for sale. Check out the "for sale" thread for more information: http://www.r3vlimited.com/board/showthread.php?t=98352
    - 1987 BMW 325is
    - 2002 BMW M3
    - 2003 BMW 540i Sport
  • dude8383
    • Jan 2005
    • 10387
    Great stance! They look awesome!
    May I ask where you got your 12mm spacer? Custom?
    • Andy
      • Nov 2005
      • 121
      Thank you.
      I purchased the spacers from Tuner Motorsport. They are manufactured by H&R.
      - 1987 BMW 325is
      - 2002 BMW M3
      • CleanAzzE30z
        • Jan 2004
        • 11794
        nice.....I lke it a lot.
        Mariano
        • SchnellerVert
          • Sep 2005
          • 3948
          I don't normally like 17's but they look good on your car. Sitting on the ebrake makes it look you are tucking them. Put the car on level ground and take some pics of the stance and post please.
          Any rubb issues while making lock to lock turns? ie inner fender wheel? or rubbing the rear shock? Most buys run itty bitty width 17's good to see some meat on them. You have traditional DD tires right?
          • dude8383
            • Jan 2005
            • 10387
            Originally posted by Andy
            Thank you.
            How much did they cost ya?
            • ZM Blue Devil
              • Dec 2006
              • 13836
              Well done, thanks for sharing, didnt think 17's would look good but they look awesome. How do they compare on the track to 16's, or 15's?
              Levent
              %20levent@gutenparts.com
              Ladies:
              • E30Driv3R
                • May 2004
                • 1169
                What are the weight on those wheels?
                Looks Hot, love the SSRs
                Dan Zickel
                1995 M3, 1991 318iS, 1987 325iS
                • Ender.
                  • Jun 2006
                  • 244
                  They are listed for $95 and can be found here.
                  Keep on Keepin' on.
                  • Joe318is
                    • Sep 2005
                    • 6451
                    oh snap! ill be there next year, once my r compounds are wasted im going to run STX in the lovely OVR, prolly those same tires too.
                    EDIT: Where do you live, area not exactly.
                    Originally posted by vlad
                    • Jand3rson
                      • 37587
                      Badass. Proof for all the naysayers that are always saying that you can't run Mini wheels on an E30.
                      • bmwm3n528
                        • 3654
                        Looking business. How do you like your RT-615s so far?
                        Trevor Ely
                        '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                        '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                        • golde30
                          • 11464
                          damn, looks beefy. very nice. thats the look im going for with my next set of wheels/tires.
                          IG: @Baye30
                          • Axxe
                            • Aug 2004
                            • 3355
                            Most naysayers say that they don't bolt on. Which they don't, without machining the center bore.
                            Keep it slideways!!
                            • Andy
                              • Nov 2005
                              • 121
                              I’ll try and get some pics today on level ground. So far no rubbing at all, even lock to lock. Running the autox event this weekend should be the true test though. I use the M3 for my daily driver, this car is just for fun, but yes I do have a set of 14” basketweaves.
                              I haven’t tracked it with this setup yet, this weekend will be the first autox event on them.
                              Based on TireRack’s website, they are 13.3 lbs.
                              Will you be at the event this weekend? I live in New Albany and work in Hilliard.
                              They are fantastic, the grip level over the BFG KDW2s is night and day.
                              - 1987 BMW 325is
                              - 2002 BMW M3
