Five Hours + Blood/Sweat/Tears = Long Friday Night
  • dinanm3atl
    • Feb 2007
    • 7305
    So I got the e28 and I have a mod and maintenance regiment planned out. I know there are certain items that I had to get done on the e28 and at the top of the list are the E Code Headlamps AKA Euro Lights w/ Grill.
    I HATE halogens and sealed beam and I need HIDs so I figured I would also get a set of H4 HIDs 55W 5000K to add to the mix. I figured it would be a plug and play affair(just like my e30 and the e36 and every other car I did them in). Well I was wrong...
    First we remove the front end of the e28 at 7pm. Grills come off, sealed beam crap US buckets/lamps come out. Have our high beam and low beam plugs. Get to work with the DVOM and find out +/- and my meter is showing 8.5V. How the hell the OEM lights are even turning on I have no clue but I go with a bad ground is causing this. I check the resistance from the negative battery post to the chassis ground(A whole 4in away) and it is 85ohm... That is unheard of! Horrible! So I spend an hour removing every ground, cleaning and redoing it. I even build a "Grounding Kit" and add that to the car and still nothing.
    Now I rush to the parts store(Autozone because it is 8:30 and NAPA is closed) and get 2 relays, some fuse holders and extra wire. I spend the next couple of hours building a fused relay harness for the low beam of each side and FINALLY the HIDs work on the switch! High beams work too! Put everything back together and drive home...
    Today I spent the a good portion of the day with kendogg(fellow bf.c member) rebuilding the ignition system. Fresh everything and a valve adjustment + valve cover gasket.
    Coming Soon - 20% Tint(Monday) - Full Suspension Rebuild(In Trunk haha) - Yellow "Rally Lights" - Bumper Tuck
    Guess it was worth it :)
    Before:
    After: Excuse the dirt... It rained like mad here!
  • 5spoke
    • Sep 2007
    • 1729
    Looks sweet dude!
    • e30pwr
      • Oct 2007
      • 642
      I approve. Where are you getting your tint done? I am going to need mine when I put new audio stuff in. The high schoolers at my school are notorious for stealing things.
      • dinanm3atl
        • Feb 2007
        • 7305
        I got a local hook up with Hot Spots Tinting. Their mobile Tinter Bridgette does all my cars. I won't let anyone else do it.
        • Stevie30
          • Apr 2007
          • 1534
          Are you bringing the E28 to the Dragon? Can't wait to see it!
          1991 325ic and 1991 318is
          • dinanm3atl
            • Feb 2007
            • 7305
            Oh Yes!
            It should be setup by then for a very sweet night time run through the dragon :)
            Have a very "2002ish" mod coming ;)
            • Tree18is
              • Mar 2004
              • 2703
              how much does the lights and grills run?
              • dinanm3atl
                • Feb 2007
                • 7305
                Depending on condition and location but normally in the 300 range.
                Local friend had these so I saved on shipping so 225 + 55W HIDs + Lamin-x + Wiring Kit I built
                • JasonC
                  Site Manager
                  • 14451
                  Does the lows have city lights? If they do, could you get a picture with them on in the dark?
                  1992 BMW 325iC
                  1978 Chevrolet Monte Carlo
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    They do but not wired in.
                    • 2002maniac
                      • 4260
                      cliffs notes?
                      5-hours + blood + sweat + tears = Yellow highs
                      looks good!
                      • Huff
                        • 2488
                        Can't wait to see it in person..
                        • dinanm3atl
                          • Feb 2007
                          • 7305
                          Originally posted by 2002maniac
                          cliffs notes?
                          looks good!
                          Nope :)
                          Equals 7" H4 Low Beams with 55W HIDs and Yellow Highs :)
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            How do the hids work in the non-ellipsoid lights?
                            Project M42 Turbo
                            • golde30
                              • 11464
                              not very well, they mostly blind people due to nasty hot-spots.
                              IG: @Baye30
