Franken Kar
This topic is closed.
  • DCColegrove
    • 2748
    #61
    Originally posted by SamE30e
    I want to see pictures and dyno.
    11k M42?
    Yes... 11k M42
    I dont have any of my own images but here... This is what they look like:
    I've never been big on photographing this shit or keeping and showing off dyno results...
    Never really been questioned much in the real world... I'm not the "Power-plant" guy at any rate.
    • DCColegrove
      • 2748
      #62
      Originally posted by Stephen027
      I think he does hav dyno charts... i think ive seen them... so, you might actually get him to show you them :P
      Shhhh...
      I'm waiting for someone to get really stupid and offensive...
      • Fidhle007
        I can fly, motherfucker
        • Oct 2005
        • 7209
        #63
        Originally posted by DCColegrove
        Yes... 11k M42
        You're a pro photog who doesn't take pictures?
        '89 325is S50 Track Montser
        '04 X5 Daily/Tow Vehicle
        http://www.avarestoration.com
        http://www.myspace.com/brendanfiddle
        Click here if you want to be my zombie slave...
        http://www.youtube.com/user/Fidhle007
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #64
          Isn't that an s42, if anything?
          • DCColegrove
            • 2748
            #65
            S20 based on the M42
            no such animal as an s42 never heard of it untill I got here anyway...
            • DCColegrove
              • 2748
              #66
              Not of cars...
              • Stephen
                Шлем ишака
                • 10774
                #67
                i think its more of a personality thing.. some people document like crazy others dont
                i love taking pics, but that doesnt mean i like documenting... its like saying you're a track driver? but you dont like being in rush hour traffic?
                at least thats how it is for me
                • Ray Smoodiver
                  • Jun 2004
                  • 8809
                  #68
                  S42 was late model E36 320i touring car motor.
                  • Gooch
                    • Dec 2006
                    • 1674
                    #69
                    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                    '87 535i - Vacuum brake conversion [SOLD]
                    '93 525iT - 5-speed swap - 320k and counting
                    '09 328xi - 6-speed
                    • DCColegrove
                      • 2748
                      #70
                      Yes... Never heard it refered to as an "S42" before the internet threads.
                      (I wonder if now this will blow up and get locked as well)
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        #71
                        S42B20 (Version: 08/1995):
                        * Stroke = 85mm
                        * Bore = 86.5mm
                        * Compression ratio = 12.4:1
                        * Total displacement = 1.997ccm
                        * Rod length = 145mm
                        * Inlet cam = 312 degrees (spread: 94) (Eö=40, Es=48 (@ 2mm lift) )
                        * Exhaust cam = 304 degrees (spread: 98) (Aö=45, As=28 (@ 2mm lift) )
                        * Inlet Valve diameter = 35mm
                        * Exhaust valve diameter = 32mm
                        * Inlet port metrics: W=52mm, H=29.7, Radius=14.85mm
                        * Slide throttle diameter = 46mm
                        * Header = 4-2
                        * ECU = ECU4A.1
                        * Power DIN 70020 = 285PS / 207kw @ 8300rpm
                        * Torque DIN 70020 = 245Nm @ 7000rpm
                        * Max rpm = 8500rpm (FIA regulation "SuperTouring")
                        * Gasoline quality = Super Plus (Oktan min. ROZ 98)
                        Then spin it at 11,000
                        So you made identical power to the above spec, but at 11k instead? Why?
                        • Axxe
                          • Aug 2004
                          • 3355
                          #72
                          * Stroke = 85mm
                          * Bore = 86.5mm
                          * Header = 4-2
                          * ECU = ECU4A.1
                          Because bullshitting is fun until someone questions you, and you sidestep those questions.
                          Keep it slideways!!
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            #73
                            Last few posts are really buttering your bread Colegrove. Don't worry, we would have still liked ya had it not been for the lofty, unsubstantiated claims. But now you are getting into murky water.
                            • dude8383
                              • Jan 2005
                              • 10387
                              #74
                              are you digging your own grave on purpose?
                              • Lof8
                                • Oct 2006
                                • 2827
                                #75
                                I never really considered buying any of your chassis braces or other e30 parts that had incredible amounts of "OCD" research and development backing them. I did, however, respect the apparent build quality of the pieces and the fact that you were making e30 products.
                                Now I know that you're a fucking retard with a friend who can weld. Your claims are stupid and defenses are worse.
                                Because of these 2 threads, ALL of your credibility is gone and probably most of your potential product sales through this site.
                                Stick to wedding photography.
                                S50'd
                                Originally posted by TDE30
                                What is this faggy shit I have happened upon?
                                I can always live in a M3. Can't M3 a house.
