My afternoon
  • Erick
    Official R3V Drifter
    • 11169
    My afternoon
    All was good though... AAA has my car on file lol. I not only got the flatbed they use for exotics (Ferrari's/Lambo's/etc), but the AAA driver recognized my car from local shows :p
    Has anyone had issues with the driveshaft bolts? It's the 2nd time that I shear them clean off the tranny flange. The first time it happened, it seemed like one bolt fell, and the other two couldnt hold the driveshaft together.
    To make sure I didnt get them loose again, I loctited the f*ckers when I put the new ones in. Well... it happened again today. I lost the bolt in Miami yesterday... started feeling the vibrations again.... and the car almost made it home... breaking a few blocks away.
    Go figure.
    And I got a new job starting tomorrow, so no more free time to go fix the car *sigh*
    Fun day tho. Ish. :p
    - Erick
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
  • Sean
    • 5793
    What's this flatbed like? Does it like have zero angle from the ground, so you don't hit your lip or exhaust? I want to use one of those sometime!! woo woo! Glad you got it home ok! :)
    - Sean Hayes
    • golde30
      • 11464
      i say get some grade 10.8 bolts to replace the stock grade 8.x. then you should be good.
      IG: @Baye30
      • Il Duce
        Non-Mod M42 Modder
        • 5044
        DAMN that thing looks mean.
        • Erick
          • 11169
          Rear looks better :)
          Or it will when I get a chance to clean it up. All I need is a rear bumper and paint. And a certain someone here sends me my euro plate filler. :p
          Feedback Thread
          • SpartanTiger81
            • Sep 2007
            • 555
            That thing is dirtay! Hahah
            • Stu
              • 4083
              Nice, love the extended gurney :D
              • Aptyp
                • 6584
                +1 on the stronger bolts suggestion. How's your guibo? is it possible that some how there's play between guibo and diveshaft?
                • Raxe
                  • 5346
                  Needs bump strip for the rear passenger side door. :hitler:
                  • SamE30e
                    • Sep 2007
                    • 4319
                    What grade are the bolts that are on it presently. Chances are they're Grade 8's, I think the tensile strength on them is 110k psi. Since you only need 3 and you want to be sure they don't break you can go grade 12's which won't break for sure.
                    1985 325e 2.8 Turbo VEMS
                    • Il Duce
                      Non-Mod M42 Modder
                      • 5044
                      fucking raw as hell. love it.
                      • Erick
                        • 11169
                        The bolts I picked up off the floor. I ordered them through the dealer because of how precise they have be in length. The car is sitting outside my buddys shop tonight so I will check tomorrow morning before work.
                        Feedback Thread
                        • T.Dot_E30
                          • Mar 2004
                          • 286
                          awsome, did you cut the hole in the rear valence so you still have it's use?
                          Otherwise you dont really need to cut it out.
                          • aaron.j
                            • Jan 2006
                            • 529
                            I had a similar problem with my turbo m20, check to make sure the rest of your driveline is in good order, (diff bolts loose? csb good? ujoints good?) I ended up putting a new driveshaft in and never had a problem again.
                            • Jand3rson
                              • 37587
                              Love the new front end, Erick. :up:
