Hey guys, wanted to introduce myself and my ride. My name is Ryan and this is my VooDoo E30 Build. Car is wrapped, with a full M-Tech 1 kit, on Broadway Static coils and CCWs.
Currently undergoing built M50 swap, half cage, interior and more Bought this car almost 4 years ago from an elderly Spanish gentleman in Jersey. Car was converted to manual very sloppily.. incorrect tranny mounts, sloppy shifter. I couldn’t tell if I was in 1st or 5th unless I was moving lol. Body needed some help, top was ripped, and suspension was shot. But it was my dream, a red e30 convertible. Scooped it up and got to work! Just under 2 years later car was up and running and looking how I wanted it for the most part. It’s been a very long road since then, and the car is finally about to come out of the shop again. I figured I could post some “current” before photos for you guys so I can update with some progress! ‘89 325i Manual Vert -Purchased December 2017 -Full tear down/disassembly -All body rust addressed and under coated -Fuel Tank cleaned out and sealed -New Fuel Filters -New Fuel Lines Front to Back -New Brake Lines Front to Back -ECS Exact Fit Stainless Braided Lines -New E-brake Cables and Shoes -Completely New Brakes (pads, rotors, lines, booster delete) -Subframes reinforced and powder-coated -Rebuilt all CV Joints and Axle Hardware -E46 ClubSport Steering Rack -All New Hubs & Bearings -Broadway Static Coilovers -SLR Drift Angle Control Arm Kit -Upgraded Sway Bars -Full Poly Bushing Set for Diff and Chassis -Performance Rear Shock Mount Kit -Front Upper Strut Bar -Upgraded Poly/Metal Flex Disc -Short Shifter Kit -South Bend Clutch Kit
-Wire Harness Simplified and Taped
-ABS Delete
-Power Steering Delete
-A/C Delete
-Spare Tire Well Delete
-Charcoal Canister Delete
-Third Brake Light Delete
-Antenna Delete
-Engine bay partially shaved, tucked, and cleaned up
-Battery Relocation
-Timing Belt, Water Pump, Thermostat
-Radiator
-Aftermarket Pull Fan and Smaller Push Fan
-Clutch Fan Delete
-All New Hoses, Wires, Gaskets, Spark Plugs, Coil Packs, Sensors, Etc
-K&N “Cold” Air Intake
-Vibrant Resonator
-Magnaflow Muffler
-Custom Gauge Cluster
-17” CCW Wheels
-Full Rare Mtech 1 Bumper Kit incl. Spoiler
-Euro Fog Lights And Signals
-Custom Front Splitter
-Euro Smiley Headlights
-Euro Grille Set
-RARE StarTec Tailights
-Fresh Purple Vinyl Wrap
-S2000 Push Start Button
-ABS Delete
-A/C Delete
-Antenna Delete
-Battery Relocation
-Radiator
-Clutch Fan Delete
-Vibrant Resonator
-Magnaflow Muffler
-17” CCW Wheels
-Euro Grille Set
