Suspension overhaul, Long over due and a few other things.
  • e30this
    • 3580
    Well I have been collecting parts for some time now and now has come the time where I get to do a full suspension rebuild along with a few other things that needed to be replaced.
    So this is a photo of what I have.
    Here is a list of what is in the photo.
    Reinforced and painted front subframe
    E36 328 steering rack.
    New inner and outer tie rods.
    Power steering delete plate.
    New control arms.
    IE 22/25 sway bar kit.
    AKG rear subframe mounts.
    AKG trailing arm mounts.
    AKG dif mount.
    AKG offset cabs.
    AKG rear shock mounts.
    AKG Motor mounts.
    IE Street and track camber plates.
    New billie sports front and rear.
    Turner motorsport SS brake lines.
    Ground control coilovers 500 front 700 rear.
    New euro trim front and rear.
    Mishimoto alum rad.
    10 inch 1500 CFM fan.
    Cross hair plates for my high beams.
    All new bolts for the front.
    Only thing that did not show up yet is the IE rear camber kit.
    Im still waitting on that as always, sparco front strut bar and new bolts for the rear trailing arms and dif.
    I just replaced the brakes with brembo blanks and PBR ceramics so thats not needed at this time. Iam going to ditch the ABS and run all new gas and brake lines when all of this work takes place. I have a leaky brake booster so thats being replaced at this time to.
    Should feel like a brand new car.
    I will take many photos of this while everything takes place. Should be fun.
  • Naplm00
    • Nov 2008
    • 1573
    picture fail
    i just did almost the same work,
    shocks, springs, sways, shockmount bearings, rsms, and all the above bushings and control arms, went OE rubber on everything except the subframe bushes
    Good luck...mine was a 2 day backbreaking adventure
    88 325ic ~~~> Rusty and ugly
    85 E ~~~> RIP
    • e30this
      • 3580
      Picture works for me, Refresh the page.
      Im not worried about back breaking work. I have a fully equiped garage with lifts. :)
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Works for me. Gonna make it a bolt in assembly? Use an engine brace up top and drop the old SF our with everything on it, then use a trans jack to lift the new assembly up/in?
        • kronus
          • Apr 2008
          • 13032
          It seems like you only have one front strut.
          cars beep boop
          • e30this
            • 3580
            Thats about the only way to do it. ;)
            Oh I have both, I lent one to showstopper and waitting for him to return me another one.
            • Turf1600
              • 9815
              What did all this cost you?
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Some people would do it one component at a time.
                • e30this
                  • 3580
                  Reinforced and painted front subframe FREE
                  E36 328 steering rack. FREE
                  New inner and outer tie rods. 110.00 Shipped
                  Power steering delete plate. 35.00 Shipped
                  New control arms. 225.00 Shipped
                  IE 22/25 sway bar kit. 250.00 Shipped ( it was used )
                  AKG rear subframe mounts. 130.00 ( diff mount came with it. ) All shipping for AKG was about 20.00
                  AKG trailing arm mounts. 95.00
                  AKG dif mount. ( see above. )
                  AKG offset cabs. 60.00
                  AKG rear shock mounts. 100.00
                  AKG Motor mounts. 50.00
                  IE Street and track camber plates. 300.00 shipped
                  New billie sports front and rear. 380.00 shipped
                  Turner motorsport SS brake lines. 115.00 shipped
                  Ground control coilovers 500 front 700 rear. 430.00 shipped
                  New euro trim front and rear. 160.00 shipped
                  Mishimoto alum rad. 190.00 shipped
                  10 inch 1500 CFM fan. 25.00 shipped
                  Cross hair plates for my high beams. 35.00 shipped.
                  All new bolts for the front. 25.00
                  New sparco bar 130.00 shipped.
                  IE rear camber kit. 100.00 Shipped.
                  Total for everything was 2965.00
                  • CorvallisBMW
                    Long Schlong Longhammer
                    • 13039
                    $3K in just suspension? Damn son. Still, you're going to have one sweet-handling car afterwards.
                    • BDK
                      • Jul 2008
                      • 684
                      yeah,
                      throw in an e30M3 5 lug conversion and you are really talking some money,
                      ask me how I know?
                      Imagine if you had to pay someone to install it all too...
                      what we do for 20 yr old cars is just hilarious....
                      • alpinaclone
                        • 820
                        Good stuff. I have to say the bushings aren't fun, but they are worth it. I need to score some camber plates and coil over sleeves and then step up to an e36 rack. Then my suspension will be pretty well dialed.
                        You'll have to tell me how the 328 rack is without power steering. I jettisoned that shit a while back and don't want put it all back on.
                        Matt
                        • e30this
                          • 3580
                          Not just suspension, I have the rad and a few other things in there that dont deal with it but it was in need of being replaced.
                          But in the end I would rather do it all at once instead of wait and replace a little here and there. Then I dont have parts fighting against each other. :)
                          • shmutzigE30
                            • 1680
                            god damn thats so sick. i wish i had $3k for suspension haha.
                            cant wait to see after everything installed.
                            PLEASE take some before and after pics
                            AW 89' 325i Vert - SOLD
                            • e30this
                              • 3580
                              Im going to try and take as many photos as I can so I can do a few write ups. I dont know how well its going to work out with dropping everything as one piece.
