Newman's E30/Skyline swap thread
  • newman
    • Mar 2007
    • 1159
    #151
    Thanks, it used to be really awesome and flat and wrinkle free, but then first the cage guy fucked it up, then the blaster guy fucked it up, then I fucked it up when the foam I filled the roof with for support somehow got behind the headliner. It's now in pretty rough shape.
    Here's an old shot from when it was good:
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
    • s_ribs
      • 348
      #152
      Diggin that paint man!
      WTB roof/window moulding
      1991 318i Sedan Project
      • newman
        • Mar 2007
        • 1159
        #153
        Just scooped up this, and the interface to communicate directly with AEM:
        And a fuel sender from summit. (Oh yeah and a 2.75 cent fitting that's backordered until october, LOL)
        • newman
          • Mar 2007
          • 1159
          #154
          Left my camera at work, but got the following done today:
          Wiper motor installed
          Cowl grill installed
          Radiator fan installed
          Wideband O2 Bung welded on
          Exhaust hanger welded onto rear of downpipe, bolts to head. Very sturdy.
          My shit is near OEM. :)
          My firewall closeoff needs to be remade, though. It doesn't fit that well, but it's going to look pretty slick.
          • newman
            • Mar 2007
            • 1159
            #155
            First thing I did was install the fuel tank level sending unit. Pretty straightforward.
            Radiator fan installed:
            Wideband bung welded on:
            Spiffy downpipe bracing to motor:
            Lastly, and most awesomely, I made this closeoff out of laser cut aluminum and pre-preg carbon fiber.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              #156
              It needs allen head machine screws. ;)
              • newman
                • Mar 2007
                • 1159
                #157
                Well, it technically needs allen head sheet metal screws...
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  #158
                  Not really, as the holes are already tapped...
                  • newman
                    • Mar 2007
                    • 1159
                    #159
                    They're not tapped they have a plastic insert that takes a course thread screw, not a machine screw,.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      #160
                      Well, then I stand corrected. I assumed you used self tapping SM screws. But now you say, I know you made a bigger hole, then buggered them plastic things in there, then screwed it all together.
                      As you were soldier.
                      • kronus
                        • Apr 2008
                        • 13031
                        #161
                        Your VC vacuum lines seem different than before.
                        Also, sorry, I'm too tired and buzzed to search through your site. Did you modify the rad support at all, and what model radiator did you manage to stuff into the middle of it?
                        cars beep boop
                        • newman
                          • Mar 2007
                          • 1159
                          #162
                          The breather lines were rubber before, but when I decided to run an e-vac scavenger, I changed them to AN
                          The radiator is a custom built unit of my own design.
                          • newman
                            • Mar 2007
                            • 1159
                            #163
                            Just tried a quick part on our new 3d printer:
                            It's actually hollow.
                            • etxxz
                              • Feb 2006
                              • 2085
                              #164
                              w...t....F are you serious? that is sick. what 3d printer??
                              No more e30s for me.
                              88 black BMW OBDII 332is dedicated track [sold]
                              88 BMW OBDII bronzit 332is [RIP 03/08]
                              91 BMW 325i [sold]
                              86 Corolla 'Ae86' HB 20v trd [sold]
                              http://youtube.com/watch?v=pTj7Hn9v5Rs
                              • newman
                                • Mar 2007
                                • 1159
                                #165
                                It's an Objet Eden 333
                                We bought it used for 80G
