1991 318i sedan project - Saving a sedan!
  • s_ribs
    • 349
    #136
    Just that one rail was worn out, others look updated since they were all plastic. Gears were good.
    1991 318i Sedan Project
    • trackjunkie21
      • Jan 2010
      • 3962
      #137
      did you replace your tensioner?
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
      • s_ribs
        • 349
        #138
        Did a month or two ago.
        • reelop19
          • Jan 2010
          • 770
          #139
          Hey man check out my map pocket speaker pods on this site for design ideas unless you want to buy a set from me. I try to tell everybody that its the way to go and its much cleaner than putting them in your door like you did. You can also maintain map pocket space depending on where you put your ring and what size speaker you're using. I just built a set for 5 1/4" speakers and didn't lose much room at all. I never make my rings either. I buy them from a guy who uses a CNC machine and I always buy the recessed kind. Believe me it makes a huge difference in looks. As far as the ED 6.5's you have make sure they're in the cab because I personally don't think 2 in the trunk will give you what you need. I built an enclosure for 4 in my rear deck but only have 2 in there now and they sound great.
          • s_ribs
            • 349
            #140
            I have seen your door speaker pods. Mine were mounted high because that's the generally accepted procedure: raise the sound stage so it's closer to your ears, not your feet. But I notice the sound missing at my feet which is why I will mount them lower if I do it again. Placement in terms of look is all preference... I kinda prefer them higher in that regard.
            Considered putting them in the rear deck lid, but only if they were ran as mid-bass drivers. From what I hear they are not good full(er) range speakers, just subs. The ski pass is every bit in the cabin as much as the rear deck lid, so they will go there. Plus, the trunk/ski pass allows for a proper box and that will make a substantial difference. And they are way to big for the rear deck lid without looking out of place (my opinion).
            How much power are you running to each e3.6 sub?
            • SiGmA_X
              • Mar 2006
              • 287
              #141
              Humm, weird that you have a rattle after addressing the main cause of a rattle. What type of oil pressure do you have? Becca's new motor has ~140k on it and all of the rails were cracking.
              :wgaf:
              PNW BMW Crew ///
              '93 325iS
              '99 528iT
              • s_ribs
                • 349
                #142
                Enough that my oil light isn't on? :D Not a clue. I don't have the kit to test it. When I get some spare cash and don't get distracted by other toys I want to add a oil pressure gauge to the car.
                Also possible that the rattle is gone and I heard something else, or that it only rattled on the first drive home. Too tired to deal with an issue so I promptly cranked the stereo so I could ignore it!
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #143
                  I have the same rattle I think. when the engine is cold it's fine, the it warms up and it sounds like a diesel and their is ticking. I'm going to replace the tensioner and see if the guides are screwed and if that doesn't help then I may need a new oil pump. I would also love an oil pressure guage.
                  • s_ribs
                    • 349
                    #144
                    Possible that we describe things differently, but it doesn't sound like a diesel at all. Never at idle - only around 3k rpm's. Rarely when cold, always when hot. Accelerating, decelerating, holding it at 3k - does it for all scenarios. I need to go for a drive and turn the stereo off to check things out.
                    The ticking is your lifters. They are either worn out and seals are shot, or you don't have enough oil pressure. Mine have always made noise but with no consistency (part of why I did the relief valve).
                    One off topic but related item is this engine was seriously nasty inside. Took a long time to scrub the oil pans clean. Currently running some Marvel Mystery Oil to clean it out (slowly I hope).
                    • SiGmA_X
                      • Mar 2006
                      • 287
                      #145
                      What are you doing Thursday? I can get you my oil pressure test kit. It should answer your questions. The dummy light won't tell you if you have enough pressure @ RPM, only (barely) at idle. And I mean barely.
                      I don't know about oil pump failures on the M42's, but if its nasty inside its possible that something damaged the pump.. Its just a long shot, and hopefully wrong!
                      Let us know how that test drive goes tonight. Beautiful evening for a drive! I wish my e36 was running!!
                      :wgaf:
                      PNW BMW Crew ///
                      '93 325iS
                      '99 528iT
                      • s_ribs
                        • 349
                        #146
                        I'll be starting my 1700 mile drive. :p Thanks for the offer though! It'd be awesome to check it for my own peace of mind.
                        Going for a drive soon. Also curious to see what the oil looks like when I drain it tomorrow/Thursday.
                        • freeride53
                          • 11972
                          #147
                          Good luck! I'm gonna drive up to Whistler next month!
                          1983 Peugeot 505 STI
                          1992 Volvo 240 Wagon
                          • SiGmA_X
                            • Mar 2006
                            • 287
                            #148
                            I'd check oil pressure before driving 1700mi, for damn sure. Unless of course you're planning on a motor swap in the near future. I hope its nothing tho.
                            :wgaf:
                            PNW BMW Crew ///
                            '93 325iS
                            '99 528iT
                            • Van Westervelt
                              • 9365
                              #149
                              Car is being dollied behind a U-hell. ;)
                              • s_ribs
                                • 349
                                #150
                                Starting to lean towards oil pressure issue more. Appears that when I have lifter tick, I have a rattle. Otherwise it's quiet. Both are much much better than before though.
