I think it has something to do with idle control. Went through realoem and could not find it ether. I know I have seen it mentioned on R3V but I just cant remember where.
Old Blue 2002 (1974 BMW 2002 Content)
crawled under the 2002 today for the first time after parking it months ago after the trans gave out. I found whats wrong...
Not quite sure what happened but the gear selector rod is WAY bent and there is something scraping at the drive shaft.sigpic
The bent piece in the pic is not the selector rod, it is just the support arm for the shift carrier. The bottom of your shift lever is what is scraping the driveshaft, it sits very close to the driveshaft even with a straight support arm. Perhaps when your guibo band broke and flew off it bent the arm a little and more driving and shifting bent it further until it was touching?
Originally posted by LJ851 View PostThe bent piece in the pic is not the selector rod, it is just the support arm for the shift carrier. The bottom of your shift lever is what is scraping the driveshaft, it sits very close to the driveshaft even with a straight support arm. Perhaps when your guibo band broke and flew off it bent the arm a little and more driving and shifting bent it further until it was touching?
The shifting on this car has been weird ever sins I bought it and I just was to lazy to do anything about it. Maybe the support arm got loose and the whole shifter carrier came down on the drive shaft? Possible? I really did not get a good look and the picture sucks. I just barrowed my land lords jack and lift the car up a few inches on the street.sigpic
Well I scored a few little somethings today to take care of my steering box problems. I spent a lot of time thinking about it and doing some mental drawings (I am a very visual thinker) and I think I can make this work. I picked up a steering rack from a 318ti sport (same ratio as a e36 M3), and I think i scored a e30 steering column with a key. I know what people are thinking... Isn't the e30/e36 steering rack in front of the sub frame and the 2002 steering linkage behind the sub frame, hows it going to work? Well I think with the right welding and fab skills I can get the e36 rack to mount to the back of my sub frame. Then all I need to do is fiddle around with the length of the steering arm off the bottom of the strut housings. Should be fun. if I can not get it to work I can always sell it.
The rack is not going to work. I did not remember that on the e30/e36 the steering rack connects to the front of the strut assembly, where as on the 2002 it connects to the back of the strut assembly. How ever a e21 steering rack will work because it bolts up to the strut assemblies in the same way that the stock steering system on the 2002 does. So I need a e21 steering rack.
e30/e36
2002 w/ e30/e36 rack
