I went on an hour long drive a bit ago. There is a bit more vibration at idle (My car idles low, which is contributing to it, I'm sure.), but they improved throttle response, engine braking is better, and they didn't add any cabin noise at road speed. These are real benign. As far as the exact same height, I'm not entirely sure. Even if money was no object, I would still go with these. Here's the guide on M42club for them.
M42 Turbo Build (Semi Budget, keepng AC!) No 56k
Figured I should post this here as well since it is finally numbers for the car. Also for the guys who are sub'd to this thread and might not see the other one.
Finally got it done for you guys... and for me obviously. There is more power left in it but I only had 3 runs (got 4 though) and I wasn't really tuning a whole lot during the cool downs.
Run 1 (3rd Gear Pull)
Not bad... but not great. 170.74hp and 167.86tq
Run 2 (3rd Gear Pull Added some timing above 5200rpm)
A little better... picked up some torque but left the efan on so had to redo this run. 167.92hp and 170.33tq
Run 3 (3rd Gear Pull Same as above because Efan was left on - Woops)
Still getting better... picked up both hp and torque by turning off the efan. Guess that thing really sucks some juice. 174.88hp and 173.86tq
Run 4... no video. It looks just like the others though.
Guess we should have been running in fourth gear the whole time... now I know for next time. 180.89hp and 208.41tq
There was a hiccup in this pull and I am thinking it is spark blowout. The dyno operator agreed it was probably the case. You can see it on the graph at 4550rpm.
My 3rd gear pulls peaked at a 164kpa and my 4th gear pull peaked at 168kpa. So about 9.5psi is what I am running. I posted my data long for the 4th pull below along with the dyno graph. Let me know what you guys think... suggestions, criticisms, etc. I'm just glad to have numbers on it now even though I'm sure there is more power there.
"A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
Looks pretty nice. The only thing that jumps out at me is that my afr, especially under wide open throttle, doesn't seem to have all the fluctuation. I'm not really sure what would cause that though. It looks like you're running about 10.5:1 most of the way through the upper rev range, and that is a bit on the low side. Certainly safe and good if you are seeing your temps rise, but I've seen better power and still no detonation or anything at 11:1 or even 11.5:1.
Originally posted by gearheadE30 View PostLooks pretty nice. The only thing that jumps out at me is that my afr, especially under wide open throttle, doesn't seem to have all the fluctuation. I'm not really sure what would cause that though. It looks like you're running about 10.5:1 most of the way through the upper rev range, and that is a bit on the low side. Certainly safe and good if you are seeing your temps rise, but I've seen better power and still no detonation or anything at 11:1 or even 11.5:1."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
Bumping your thread because I love it. I saw it on M42Club, but I can't post on there (account never got activated, I don't know who's admin'ing that place...).
Recently picked up an M42-powered sedan, and it's getting some forced induction in the future. I continually go back and forth between supercharged and turbocharged. Turbo for the ease, but a supercharger would be sexy, and I've got the resources at work to make it happen.1991 318i SOLD
2003 325i SOLD
Racecars and stuff.
thanks for the FMIC pics. Its mandatory that i keep my A/C so its good to know it can be done while still fitting it all behind the valance!RHD OBD2 M50b25 turbo build thread:
http://www.r3vlimited.com/board/showthread.php?t=384800
Originally posted by ba114 View Postthanks for the FMIC pics. Its mandatory that i keep my A/C so its good to know it can be done while still fitting it all behind the valance!
The car has been running fine though I rarely get to enjoy it anymore. I drive it maybe once a month or so. We just found out we are having our second child so this will most likely be up for sale soon after I go through it and check things out."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
