Turbo m52
  • bimmerboy12
    • Jun 2004
    • 1057
    #46
    1988 325iC Project - FINISHED!
    Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
      • 37829
      #47
      Manifold looks awesome! Sweet setup.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • So Live
        • 2512
        #48
        And turns out my boost target is 217kpa... makes sence why i made that much boost haha.
        Thanks dude!!! Jon Volk is the man!
        -Chris
        • richardb
          • 2121
          #49
          Ah, looking good mang. I sure would like a 666 manifold, but I wonder if that obx ebay mani would work for now...
          Also, where is your oil feed off of?
          Transaction Feedback!
          • pbr87
            • May 2008
            • 853
            #50
            looks slow j/k, nice e30!
            Originally posted by accident
            I have achieved the title of Douche of the month.
            Discuss.
            Originally posted by kronus
            It was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
            1990 300ZX TT 5spd ($6,000)
            1991 318i 4dr 5spd (DD)
            • So Live
              • 2512
              #51
              Jon (666fab) and i talked about trying to fit a e36 top mount in an e30. The turbo would probably be in the headlights and you probably wouldnt have any hood clearance at all. (OBX copied Jons e36 manifold)
              Oil feed is off of the pressure sender in the oil filter housing. Heres a pic of the "test fit" of the little oil manifold i made on the old NV motor.
              Now its attached with wiggens clamps but you get the idea. Notice the OEM pressure sender is on the front of my manifold.
              Yeah, im bored already. I need to man up and turn up the boost!!! (thanks!)
              -Chris
              • So Live
                • 2512
                #52
                K now i think i new some new tires. Dialed the boost to 16-17 psi and it steps out pretty hard in 3rd gear with a passenger. It spins the tires in 3rd gear at like 13psi. A few weeks ago it wouldnt spin em in 3rd at 17psi with the holset... Maybe its cause its getting colder, who knows.
                I think it has a good amount more power left in the timing maps which im afraid to step up on the street. I cant wait to see what it puts down
                -Chris
                • Schnitzer318is
                  • Jan 2008
                  • 2057
                  #53
                  Did you add more air to your tires? My turbo m42 was getting "bad" mileage (23mpg) so I checked the tires. All for corners were 10lbs low. After refilling car felt quicker again and mpg back up to 27 (if I don't get retarded with the loud pedal). Also will easily brake tires loose again.
                  In the same boat as you on waiting for a dyno and proper tuning... anxious to see numbers. Wanted 200rwhp at project beginning, but I think it will actually put down more after driving it for awhile.
                  Good luck on your dyno.
                  "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                  91 318is Turbo Sold
                  87 325 Daily driver Sold
                  06 4.8is X5
                  06 Mtec X3
                  05 4.4i X5 Sold
                  92 325ic Sold & Re-purchased
                  90 325i Sold
                  97 328is Sold
                  01 323ci Sold
                  92 325i Sold
                  83 528e Totaled
                  98 328i Sold
                  93 325i Sold
                  • tabasco
                    • Mar 2006
                    • 861
                    #54
                    I want this in my wagon....
                    ok...and in my E30!
                    • So Live
                      • 2512
                      #55
                      If anything the tires are low. I haven filled them in a while and it's gotten colder. It's probably the temperature but the car feels good haha.
                      And thanks guys!!
                      -Chris
                      • So Live
                        • 2512
                        #56
                        Saturday i decided i was going to rewire my cam/crank stuff. I wanted to add a connector to the crank so i could disconnect it and i wanted to run it under the intake like stock...
                        I opened up the glove box to pull the adapter harness and basically got fed up with unhooking all kinds of small connectors / BS wiring. I decided to ditch the adapter harness and hardwire in AEM to the engine harness. Yay another "small" task turns into a major one!
                        Long day yesterday getting it sorted out. Pics when i have the balls to shrink all the tubing (once i figure out if ill EVER want to add anything and im certain everything works lol)
                        Oh and should be on the dyno this weekend or next!
                        -Chris
                        • speedminded
                          • 291
                          #57
                          Can't believe I haven't seen this thread before! I'm planning to run one of Jon's manifolds with a GT30R on the M52. Debating on going with the multitune using the stock DME or megasquirt or something else...any suggestions? What are you doing about VANOS?
                          AUTOMOTIVE PHOTOGRAPHY │ JASONTBARKER.COM
                          • So Live
                            • 2512
                            #58
                            Well im running NonVanos cams and what not so i dont have to deal with it.
                            If i were you id get someone to chip tune the stock ecu. (TRM or Nick G from technique tuning) Standalone ecu is a TON of work and its really a difficult thing to get working well. Unless you pay someone to get it running (like i did). I didnt have very good luck with megasquirt but thats not to say it dosnt work. I like my AEM so far but like i said, lot of work and i paid Maximum Psi to get it running for me.
                            -Chris
                            • BUDNUNTA
                              • Apr 2005
                              • 996
                              #59
                              Your car is great.
                              I like your oil manifold setup I think I'll steal your idea for my m42.
                              Are you still using the oil drain into the timing cover?
                              I feel your pain with that wiring
                              I just chopped of my motronic connector to attach it VEMS
                              What a pain, are you using any sort of fuse block before your computer?
                              Cant wait to see what kind of power your car puts down.
                              Spinning in 3rd, I cant imagine what thats like.
                              Hunter
                              We're out there in here.
                              • So Live
                                • 2512
                                #60
                                Thanks dude!!!
                                Still draining turbo oil to the timing cover, yes. No issues and seems to work better on these motors than draining to the pan. With the old drain to the pan id loose about a quart of oil when i unhooked the drain...
                                Haha yeah wiring blows! And im using this thing for power gnd distribution:
                                Compact ATO® / ATC® fuse block consolidates branch circuits and eliminates the tangle of in-line fuses for electronics and other appliances.
                                Pretty nice product. I like the screw terminals more than the push on spade ones. I think theyre more secure. Im running power from the ignition to it and a big 4 gauge wire from the gnd side to the engine block. Seems to be working quite well.
                                And i ended up ditching the oil manifold. It looks like its leaking for some reason. I think the mating face for the oil pressure sender wasnt flat / smooth enough. oh well, the cluster light wasnt working anyway... Ideal solution would be to run a sensor with the ecu and have it turn the car off or something if pressure gets low... Im going to try to get it working again but spewing oil on the dyno isnt fun.
                                Im going to try to get my AEM "dyno math" set up tonight and knock sensing tomoro. Basically takes a bunch of calculations and figures out how fast your accelerating and gives you a dyno like plot in the log software. Hopefully have knock all sorted and id like to see how the dyno math in AEM compares to the real deal. Also got manual boost control hooked up for easy changes on the dyno as it takes too many runs to dial in a boost pressure via the EBC.
                                -Chris
