Rescuing a 325e... with pizazz
  • 318isbmw
    • Nov 2005
    • 2843
    Cant wait to see this done. Absolutely love the e46 so I've got a good feeling about this one.
    • tg318is
      • Jun 2008
      • 2052
      holy crap huge pics! nice build!
      Tim.
      • Mike
        • 932
        Whats the suspension setup on the e46?
        Supatek -noun - your basic know it all
        • hi its me alec
          • Apr 2008
          • 478
          KW V2 Coilovers - all the way down, full stiff
          Meyle HD Control Arms
          Powerflex Control Arm Bushings
          AC Schnitzer Sway Bars
          New OEM Steering Rack & Tie Rods
          Spacers & Hub Extenders - 10mm Rear, 5mm Front
          Needs camber plates and rear camber arms ASAP... can't wait for that day. Vorshlag camber plates drop the car an additional 1.5-2.0"
          WTB: early e30 sedan front doors
          • Mike
            • 932
            What really woke it up in the steering, the new rack and tie rods, or the coilovers?
            • hi its me alec
              • Apr 2008
              • 478
              To be honest, everything has helped to refine the steering - nothing really stands out in my mind. The coilovers provide a good manageable amount of shock travel, which is probably the most important thing on a 'race car'; sway bars stiffen it up in the corners, especially high speed; steering rack and tie rods just tightened everything up about 15%.
              • Mike
                • 932
                Yeah, my e46 needs some funding, just pondering pss kit and rack conversion. upgraded rear trail bushings too.
                • hi its me alec
                  • Apr 2008
                  • 478
                  Never heard of someone dong a steering rack conversion on an e46, or are you talking about converting away from an overboosted rack?
                  • hi its me alec
                    • Apr 2008
                    • 478
                    So I finally got the wiring harness in the mail, I have it laid out across my bedroom floor right now. Here's my info on the wiring details:
                    1. oil pressure sensor BRN/GRN or BRN/GRY
                    2. front coolant temperature sensor (ECU) BRN/RED BRN
                    3. rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
                    4. crank position sensor YEL
                    5. cam position sensor YEL RED/WHT BRN/ORG
                    6. VANOS solenoid RED/WHT GRN/BLU
                    7. knock sensor, 1-3 BLK NCA DME PIN 70
                    8. knock sensor, 4-6 BLK NCA DME PIN 69
                    9. throttle position sensor (TPS) BRN BRN/BLK RED/YEL
                    10. intake air temperature (IAT) sensor BRN GRY
                    11. idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
                    12. Evaporative emissions valve BRN RED/WHT
                    Should have something done by Friday!
                    • hi its me alec
                      • Apr 2008
                      • 478
                      Also, see the round plug with silver ring inside? I was under the impression that this was an auto-only connector, but I guess this harness was from an OBD1 325is 5sp. Confirmed this several times with the guy I bought the harness from... the connector only has 4 pins wired.
                      • Mike
                        • 932
                        Overboosted, yes i think that my car does have too much assist. I tried doing homework on the situation, but my e30 project took precidence. E46's went through some revisions in there racks, on early models right? Mine is a 2000 323i, and realoem.com shows different pipes available that bolt directly to the rack, are you familiar with this?
                        • hi its me alec
                          • Apr 2008
                          • 478
                          old harness almost out, should start making some real progress today
                          • Jean
                            • 18228
                            Wow, that's a lot of work man! You should swap the engine now from your one e30 into your other one with no rust ;)
                            j/k!!!!
                            • hi its me alec
                              • Apr 2008
                              • 478
                              j/k!!!!
                              Some day, I will. hehe
                              I'll make a new thread whenever the chassis is painted
                              • hi its me alec
                                • Apr 2008
                                • 478
                                Sad knock sensors... both are broken like this. Does this matter? I broke them taking the harness out, didn't unplug the connectors and yanked on them, guess they're fragile. Shit.
                                But at least I got the harness out!
                                Nekkid M50
                                my reward... what could it be?
                                THE best bbq :)
