Checklist of shit to do
  • Streichholzschächtelchen
    • Jan 2009
    • 1670
    Because I keep forgetting things. As I do things I'll delete them.
    make the seats com back up when you adjust them
    a piece of the throttle linkage is broken, could be replaced
    find a non bubbled e-brake console piece
    pedals look whooped
    shift knob is whooped
    fog light switch is beat looking
    drivers seat belt is showing wear and tear
    wrong rear carpet piece (epic fail)
    shifter stuff for short shift
    boots
    modify my e36 switches
    Steering wheel bolt things could use a nice coat of black paint
    trim center console / do something about steering rack cover to install padded knee bolster
    install the goddamn radio already, wire aux. cable under center console to predetermined area
    buy some floor mats, the originals are destroyed
    fab up the drivers side mirror
    spray the firewall piece I sanded
    remove AC condensor
    front and rear window insert stuff is brown now, needs to be chromey again
    build heat shield
    grilles need a euro touch, and a dremel touch to allow slightly better air flow
    smileys, wire turns into the driving lights, and use a rear bumper piece up front
    spray tail lights
    side marker delete
    spray bumper shrouds
    get the body panels I've been eying
    sell BBS spoiler
    have the fenders rolled
    install cabby front sway
    acquire a stiff rear sway bar
    3rd brake light delete
    remove the blue tooth antenna from the rear of the car
    brakes!
    order springs and shocks
    reinforce suspension mounts
    shine up the diving boards and window trim
    start on the OG roof rack
    front and rear strut bars eventually
    grind down/off the bullshit from the engine bay that used to hold things I've removed
    spray valve cover and intake manifold
    finish the exhaust
    e28's lighter flywheel
    make drivers side window not grind the gears when all the way down
    make the passenger side door unlock everything again
    bmw center caps for the konig bbombs
    a-arms and tie rods need to go in finally
    buff off the faded pinstriping, or keep it? Need to decide and go with it
    do something with the sideskirts in my closet
    windshield squirter cap delete
    maplight rearview
    camber plates once the suspension is in
    order the speakers, build the sub box
    cam
    hella fogs, most likely going to chop the front valance to fit
    get a windshield that doesn't have an annoying rock chip
    get the windows tinted but not too dark
    black seat backs need to be replaced with baller tan backs to match the headliner
    get those cupholders, the husco one is annoying
    cap the holes where ac lines went
    figure out a battle plan for the battery tray and jack area, little rust spots are showing
    headers would be nice, way down the road
    Tuck the cables dangling in the engine bay that used to connect to things now removed
    fucks with a vanity plate
    have metal magic shop trapezoid an oil pan
    do something about the dying clutch
    all new bushings, motor and tranny mounts
    wheel bearings aren't going to stop making noise unless I get off my lazy ass
    sell all kinds of parts to people that would put them to use
    mono wiper would be pretty dope
    lightweight spare
    light battery
    kiwi the fuck out of the exterior plastics and rubbers
    find little containers for under the seats where the foot ac things went, and cap the vents that used to go to the rear passengers
    get lugs that don't look like shit
    brake booster and master cylinder stuff
    drop hats
    chop a coil up front on the new springs
    remove spring pads
    steering rack with a better ratio to be modefied...
    shout obscenities at inanimate objects
    Dreams for another day:
    spare motor, to be stroker with bottom end work, of the torqueyness
    itbs of the awesomeness
    turbo build of the greatness
    Body panels of the lightness
    euro bumpers of the shineyness
    I missed a thing or two that I have written on my to do sheet, gotta go over it once I get to the apartment to finish the list. 8)
    Jah bless! :pimp:
  • Court M3
    • Jan 2004
    • 6713
    sounds like a comprehensive list. Where are the pics of the car?
    Continuous For Sale Thread
    323i s50
      • Jan 2009
      • 1670
      Too lazy to snap pics, gotta get around to that. Spent 7 hours on it today though cleaned the interior and engine bay up, removed AC stuff behind the glove compartment and some sound deadening, about to remove the AC condenser as soon as I order the m3 fan mounts.
      Jah bless! :pimp:
      • Jean
        • 18228
        M3 fan mounts? Are you talking about the 2 brackets to install aux fan w/o condenser?
          • Jan 2009
          • 1670
          Lol yeah I couldn't think about what it was called, but I knew what I meant.
          Jah bless! :pimp:
