Specs-
Completely stock. The car currently has a messed up idle and is hesitant on the throttle when warm. It seems like a typical problem that is often misleading. I was going to sell it but decided to keep it as a project. It needs body work and some rust repair but first I want to get it running perfect then Ill rip it apart again and paint it when its warmer out. This car is going to be my summer DD.
Stroker Parts-
Have:
i Wiring Harness
i Instrument Cluster
i ECU 173
i Intake Manifold
i Throttle Body
i Injectors
i FPR
i Fuel Rail
Working on getting:
i ICV
i pulleys(fan, water pump, crankshaft)
i belts
i thermostat housing
i AFM
i Plug Wires
731 Cylinder Head and bolts
i Duel exhaust
i Radiator and expansion tank
i Single fuel pump
Headers?
As for the suspension, here is my plan-
Front:
Cabrio swaybar
Wheels- 16x8 Diamond Racing Steelies 215/40 Streched tires +5mm Spacer from H&R
Brakes- Brembo drilled rotors
Shocks- Bilstien Sport
Springs- Koni or H&R
Shock Mounts
Rear:
Wheels- 16x10 Diamond Racing Steelies 215/40 Streched tires
Brakes- Brembo
Urethane bushings
3.73 Differential
Let me know what you think. Ill keep you posted.
