Got bit by the turbo bug.
  • IronFreak
    • Dec 2012
    • 3702
    #181
    Originally posted by jute91
    nice :) where did you buy those rear fenders or did you make them yourself?
    They are DTM fiberwerkz flares I believe.
    Instagram @rebellionforge
    • obes
      • Apr 2012
      • 1156
      #182
      yes dtm son! ^
      heard about the #s nigel!
      -1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
      -1987 Coupe (17x10.5"/17x14")
      Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
      Follow me on Instagram: obes_sebo
      For more updates:)
      Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838
      • einstein57
        • Jun 2007
        • 10780
        #183
        They are late model esm flares. Hence the cutting.
        www.gecoils.com
        • einstein57
          • Jun 2007
          • 10780
          #184
          Matte white in the works.
          www.gecoils.com
          • Zacm829
            • Jan 2008
            • 1919
            #185
            Did you find out the cause of your clutch screech?
            1987 325i-M60b44 swap
            • jaywood
              • Jul 2010
              • 4528
              #186
              What type of Oracal is that?
              • einstein57
                • Jun 2007
                • 10780
                #187
                No. Just drive it till it went away. Pretty sure it was the new pilot bearing
                651
                www.gecoils.com
                • jaywood
                  • Jul 2010
                  • 4528
                  #188
                  651
                  Nice, I've looked into that stuff quite a bit. Budget friendly vinyl wrap, I like.
                  Where are you going to put the "transition" for the rear quarter panels/roof?
                  • einstein57
                    • Jun 2007
                    • 10780
                    #189
                    In the works
                    The bottom of the C pillar along the hard line. Really the only place to do it with out being a sore thumb
                    www.gecoils.com
                    • einstein57
                      • Jun 2007
                      • 10780
                      #190
                      So after lots of messing around cutting and welding with out a clue to what i'm doing, this is how the first quarter panel came out. If your wondering why so much abuse its because i'm installing late model flare on to my early model. The flare won't sit flat on the the sheet metal so i had to cut and hammer little by little until could see how they would sit and how much material needed to be removed.
                      Then i made a template using some construction paper thats used for laying on the floor so you don't mess up your carpet during construction.
                      Transferred it to the other side and cut away the outer skin and bent it back. Then i cut out the inner fender.
                      Then i mocked up the passenger flare and the molding strip did not line up. So now i'm thinking great, my template was a bust. But then i taped the left and right pieces to each other and the photos speak for themselves.
                      Since i'm planning on shaving the trim its not that big of an issue. I then proceded to trim the lip. Not sure why they were made with a huge inner lip if they are intended to allow wider wheels and tires
                      All mocked up
                      Decided to paint them black so they don't stick out so much
                      And with my coilovers on the lowest setting with new factory upper spring pads. The rub like crazy. I wish the lip did not taper in. If it was flat or tapered out i could easily drive around dumped. I'd need to step down from a 255 to a 245 or add some more fiberglass to space it out more.
                      www.gecoils.com
                      • dmoney(AB)
                        • 1372
                        #191
                        I approve!!
                        Looks killer
                        My dream is to fit 275s for ultimate traction.
                        mtech1/2jzgte/r154/275tire
                        function>form
                        • einstein57
                          • Jun 2007
                          • 10780
                          #192
                          275 Falken 452 vs 255 Federal SS 595
                          www.gecoils.com
                          • AbsorbantNut
                            Non faccio funzionare questa merda
                            • Jun 2010
                            • 2491
                            #193
                            That's a lotta beef :p
                            Love this build! Early model, plastic bumpers, turbo, coilovers, it's pretty slick!!
                            '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                            • einstein57
                              • Jun 2007
                              • 10780
                              #194
                              Well i thought i had them pretty well trimmed but a big dip proved me wrong
                              www.gecoils.com
                              • IronFreak
                                • Dec 2012
                                • 3702
                                #195
                                Doh!
                                Man, I'm really second guessing putting these on my car.......
                                Maybe it's time to look at some KAmotor's extra wides.....
