Zen and the Art of e30 Maintenance
  • TimKninja
    • 2131
    #181
    Epic project, can't Imagine the feeling of success.SO Fucking clean.
    Did you order your lines from the dealer? I REALLLY Need to do my lines, did you have to drop the tank or anything?
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • tg318is
      • Jun 2008
      • 2052
      #182
      Looks awesome! The bottlecaps look great Great on it as well!
      Tim.
      • csermonet47
        • Jul 2009
        • 937
        #183
        <3
        Are Three Vee
        Dad Spec
        • dude8383
          • Jan 2005
          • 10387
          #184
          Epic. That was quite a journey man. Really enjoyed all of the work you've done... it has finally paid off!!
          • Simon S
            • Oct 2004
            • 3758
            #185
            Thanks!
            You have to drop the tank for the one fuel vent line. The feed and return lines can be done w/out dropping anything. To do the brake line properly, I’m pretty sure the tank OR the subframe should be dropped.
            At first – I ordered just the brake line from a dealer – thinking that’s the only line I’d replace. Once I determined the other lines should be replaced as well, I generated a nice Blunt Tech order along with other misc hardware and the is lip..
            Thanks!
            Yeah – once I determined I would have to run the caps – I went into ‘damage control’ mode by blacking them, spacing the rears, and fresh roundel emblems. Cosmetically – I’m pretty happy with results..
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            • pandaboo911
              • 2070
              #186
              Your attention to detail is great, top notch work.
              How much did that new fuel tank set you back? :P
              • Simon S
                • Oct 2004
                • 3758
                #187
                Thanks man.
                Got lucky on the tank.
                It had been installed by a pior owner at some point..
                • dude8383
                  • Jan 2005
                  • 10387
                  #188
                  Rockauto has aftermarket tanks for about 160-180. I bought mine from there... no problems, only catch is that it doesn't have a screw in the bottom of the tank if you ever want to completely drain it. Otherwise, you'll have to siphon it out.
                  • Donkeyshins
                    • 34
                    #189
                    Originally posted by Simon S
                    Then I took a break and made a ground strap for the engine head. It's purpose was to prevent electrolysis from deteriorating mating surfaces.
                    First of all, fantastic work and write-up. You ought to submit this as a story to Bimmer or Roundel!
                    Second - can you provide more details on the ground strap and the grounding configuration (e.g. valve cover bolt to chassis?)
                    Thanks!
                    -D
                    • Simon S
                      • Oct 2004
                      • 3758
                      #190
                      Table of Contents post updated.
                      Thank you for the kind words D.
                      Regarding the ground strap – pretty straight-forward. I dug through my box of extra stereo wire and only found that red/power wire that was long enough. Off the top of my head – I want to say it was 8 gauge. Shrink wrap tubing was used on much of it just so there wasn’t a red wire that jumped out at you in the engine bay. I attached one end to the head using one of the bolts that fastens the engine hanger on (where you’d hook a chain on if one were to pull the motor) – ran it under the intake system – and attached it to the chassis on the driver’s side strut tower. Pretty sure it was on the bolt that holds the throttle cable in place.
                      • dnick
                        • Apr 2011
                        • 1377
                        #191
                        wow such an in depth write up, i love it. read everything and enjoyed it all. congrats to you sir, well done
                        • igor2
                          • Sep 2011
                          • 17
                          #192
                          wow .... Simon, all my hats come off. No E30 yet, but yours is quite likely the pinnacle to hold in the highest esteem.
                          • acolella76
                            • 2950
                            #193
                            Damn Simon, you're doing work. I love reading this when I should be in physics... lol.
                            Car looks so much better with the black trim. And thanks for reminding me to replace my fuel lines!
                            -Alex
                            • Simon S
                              • Oct 2004
                              • 3758
                              #194
                              YAY !!
                              50K hits !
                              Wow - thanks guys !!
                              • acolella76
                                • 2950
                                #195
                                Simon, publish this as a book. Thank you.
                                -Alex
