My E30M3 S14B23 -> S50B32 -> RB26DETT. We are alive!! p.28
The exhaust and steering issue I will have to address once the engine is in. It will NOT go through the heater, that is for sure. I have a backup plan to use hanging pedal box inside the car if there is no way to keep the twin turbos and I have to go single turbo. That way I will have room for the exhaust.
My build will not be as spectacular as newman, but I will do my best to keep you entertained :P1987 BMW E30 M3 RB26
2016 VW Polo 1.2 TSI R-Line
Originally posted by 5spokeFucking norway and your sick clean ass e30's! Yes i am yelling!Comment
Hmmm. Stock twins just might work. Either way if they dont it's going to be hitting the chassis fork/strut tower. Just maybe with how the rb26 sits angled, it would help clear the stock twins. The only quick solution would be to notch the areas that cause issues.The exhaust and steering issue I will have to address once the engine is in. It will NOT go through the heater, that is for sure. I have a backup plan to use hanging pedal box inside the car if there is no way to keep the twin turbos and I have to go single turbo. That way I will have room for the exhaust.
But what's a rb26 swap without a fat snail right next to it ;D
Y'all Norwegians will figure something out!
I have talked to people that have done it in RHD E30, and there was nothing mentioned about the strut tower. Remember that these engines is swaped into LHD 200sx's as well.1987 BMW E30 M3 RB26
Ok guys, I have now collected the engine! That thing is massive :P Block is 10cm longer than an M20. Engine was bought from a company 4 hours from me. Delivered with guarantee, compression test, bench tested by the seller himself. Converted to push type clutch and ready for mating with the R33 RWD gearbox. Also got the front part of the driveshaft.
Adding some wheel porn as well. Deivered the OZ's to the new owner couple of weeks ago. He was very happy with what he got, and I can't deny that I was very happy with how they turned out after the repolish.
Great thread. Got to the RB26 part & was going to point out that the RB series are even longer than an M30, so not much room up front for radiator or a large intercooler, then the exhaust issues etc. But you already know this.
Looking forward to seeing the progress.Comment
Got some work done today. Trying to get a overview of the project. I'm at this point seeing single turbo as an option, thought I would not like it.
So, I just hoisted it into the car to have a look at what I have to work with. First thing was that the exhaust from the rear turbo did hit the firewall.
I removed the dumps from the rear turbo and hoisted it in again. At this point the front differential was stopping to get the engine into posistion, so that have to me removed from the oilpan before I can go on in posisioning the engine.
Removed the oilpan/diff and removed the diff itself from the housing.
I like that it have these braces between the bearing caps, I can't remember what it is called. It also have piston squirters.
wow - the sound of a rb26 touches me inside like nothing else. can't wait to see videos of this!!!!91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
www.RenownUSA.com
ig @RenownUSA / @rude.scottComment
Me too this is soo wiked project, you have the right body+cool engine coming in that :)Comment
Well, that should I take as a big compliment I think!
I'm with you on that. The 2JZ is also very good sounding, but the RB26 is more...ummm..sharp if I can say that. Have been a dream to swap a RB into something unusual since the Tokyo Drift Mustang :)
Thanks! Great to have support from some people, since there is many haters on it already. But if you got haters you are doing something right they say.
Today I spent some hours tidy the garage. It was a total mess. Scrubbed the floor and got things organized. Did not have time to tidy up the work bench, so I did not bother with any pictures.
Starting to work on the oilpan tomorrow.1987 BMW E30 M3 RB26
this thread is porn... sub'd[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction FeedbackComment
DREWLIENTE
