s50b32 e30 325i tech1 project
  • HybridNz
    • Jul 2009
    • 158
    #226
    Road interior nearly complete.
    Nappa
    Have some other goodies but its pissing down outside and I cant really photo it in the garage .. Maybe tomorrow night.
    • HybridNz
      • Jul 2009
      • 158
      #227
      The stock BMW cooler was pissing me off so I replaced it with a big ass Earls oil cooler / lines (under number plate)...which extends up to the top of the bumper with the blue lines through the grill. Its all isolated and rubber mounted as not to twist the cooler frame
      You can kinda see the brake cooling ducts.
      All set for summer of time attack :)
      • HybridNz
        • Jul 2009
        • 158
        #228
        So been a bit busy ordering some new stuff.
        New Oil housing with the elusive pressed in Oil Thermostat, yes you have to buy the whole housing just for this one bit. My old one is poked shut.
        And while im at it I installed a new Ratiometeric 0-100psi, 0-5 volt industrial grade pressure sensor (Thanks to conrad for help locating one)
        This will eventually connect to my new GPS datalogger project :) (watch this space)
        Just sitting it in the housing, will seal with alloy washer once locked in.
        • HybridNz
          • Jul 2009
          • 158
          #229
          Nothing too special .. but got a second set of race wheels and a supply of slicks.
          Wheels: BBS RX 17x8 et38
          Test fit on car
          Caliper Clearance for BBK
          .. slick supply .. went halves with james
          • HybridNz
            • Jul 2009
            • 158
            #230
            Been working on the brakes recently to hunt out a few issue with over heating
            Changed out the pads to something a bit more race orientated and less best of both worlds
            Followed Ollies Gee's path and went with the V8 Super Car / NZv8 route. Performance Friction Pads
            Type 81 Medium Compound
            Bevelled edges for noise reduction, my neighbours will probabaly love me now instead of the screaming from the other pads which normally happens on warmup
            Also thanks to Ollie McDermott working on some prototypes, these are back from the laser cutters and currently being welded up. All alloy light weight.
            • Eric
              • 5142
              #231
              Originally posted by Ray Smoodiver
              Do you ever say please?
              God you're needy.
              • catuned
                • Jun 2011
                • 2324
                #232
                Truly Fantastic! :)
                Work We Do
                CAtuned Feedback Page|FB CAtuned Page
                http://www.catuned.com
                • Robe30rt
                  • Feb 2012
                  • 41
                  #233
                  N.i.c.e.!!!
                  • samiam3356
                    • Jul 2009
                    • 1901
                    #234
                    nice as always.
                    You see this BTW?
                    Originally posted by Roysneon
                    $5 shipped?
                    Originally posted by MarkD
                    You are a strange dude, I'n not answering any more posts from you.
                    • robgoesvroom
                      • 821
                      #235
                      I'd like to see more of the brake duct backing plates! Awesome E30!
                      • HybridNz
                        • Jul 2009
                        • 158
                        #236
                        More updates:
                        :) -- this is actually leading to something :)
                        small update ... kind of pointless and expensive to do, but i'm a details guy :/
                        Before
                        After: Genuine recover
                        Roof rust be gone
                        It was pretty bad if some of you remember ... decided it was more than time to get something done about it.
                        Rocking the RXs for the time being while I put it back together :)
                        Wet weather weekend stuff rules :)
                        So starting to put the final touches on the car of all those little bits that have annouyed me. Will have some more interesting updates come soon but for now you have this :)
                        I decided to splash out on some new OEM replacement pre-fl tail lights. Will just thank Jon the Pom for pointing me in the right direction for these.
                        unboxing
                        Old tail lights doing what all e30 tail lights do best and cracking. Still not bad for 26 years old. The right side had spider webbed pretty bad
                        And the left side had the usual inner piece fall off. Its so strange that this combo always happens to every car?
                        Removed the old lights and cleaned up the area the new sealing gaskets would sit.
                        After messing around with the wiring and plugs which had started to loose their bite on the terminals .. here they are installed! :)
                        • catuned
                          • Jun 2011
                          • 2324
                          #237
                          nice
                          Work We Do
                          • sayed ali
                            • 762
                            #238
                            Wow! Amazing :)
                            M20B28 Turbo
                            My Build Thread
                            http://www.r3vlimited.com/board/showthread.php?t=255839
                            • Loupoz
                              • Feb 2012
                              • 166
                              #239
                              I love your project, hope my own moneypit can be half as awesome as yours is some day!
                              And you really should get those RX painted black :pimp:
                              My 325I Mtech1 S54 Build
                              • HybridNz
                                • Jul 2009
                                • 158
                                #240
                                I hear ya about the money pit side of things !
                                Yeah way ahead of ya there on the black wheels thing.
                                I have a set of geniune 18 inch LMs that the car runs on the road with. These will stay how they are. (pictured in my sig)
                                A set of 17 inch BBS RCs that im gonna paint black first which are my trackhack wheels (slicks) The need to be black because they get covered in shit on the track.
                                The 17 inch BBS RX's are just my transport wheels so I dont get my other wheels messed up while in the paint shops etc. Not so worried about doign anything with these at this point.
