Project Update for Feb 18, 2010: With last week's Thursday work night snowed out (we had over 12.5" of the white stuff - a 24 hour record for Dallas) and some missed work nights over the holidays, the team was getting itchy. We had 6 of the $2010 Team members here Thursday night to turn wrenches on the E30 again - it was bedlam! :D I'm behind on posting pics so here goes:
Chris and Paul pressing in the '95 LCAB bushings. We might go back with poly or Nylon (we'd machine them to save $). The "composite" bushings (aka: wood shim!) had to go
We had 2 different teams working on different things to stay busy, and in less than 2 hours we had the pair of '96 M3 LCAs on, new offset '95 M3 bushings (eBay) in the LCAB "lollipops" in, the E36 steering rack installed, with trial fits along the way. We also decided to up the scheduled "first test" date by 3 months, including some road course testing (more on that at the bottom).
Costas, Dave and Derek thrashed on the LCA's and E36 steering rack
The old E30 steering rack brackets were bent up pretty well. Once we finalize the up/down location we're going to beef up the lower mount with some steel. Hopefully this will then withstand the higher cornering loads of 275mm Hoosiers at high speed track events.
The rack mounts were cleaned and straightened
The E36 rack has about 1/2" gap to the factory E30 mounts. This is nice - it will allow us to shim the rack up/down to correct for bump steer
The holes on the E36 rack lined up perfectly with the E30 brackets, and the end-to-end length was fairly close to the E30 rack. The E36 rack moves the power steering hose ports to the outside of the rack, away from the V8 motor we're adding. Its also a lot faster ratio rack than anything that came in an E30 - and was a freebie! A cool customer who had swapped in a Z3 rack into his E36 track car donated this well used (275K mile!) E36 325is rack to the cause. Don't let the cleanliness fool you - that's just my pressure washing and OCD detailing on what was a dirty old rack. :p
The '96 LCAs on and the rack in place
The wheel has indeed moved forward, but as expected after reading the great write-ups on these swaps on R3vlimited forums, this is far from perfect. The right fix probably does involve E36 M3 spindles, but we cannot and will not do that for this project car. Why? It will pound our budget, and doesn't fit the theme for this car - a fast car built with cheap parts that nobody wants.
Going to E36 M3 spindles mean we'd need M3 rotors, calipers, and more. We're not going to even try to pull that one over. The two sets of E36 non-M spindles/rotors/brakes we've picked up were free because nobody wants them, and that's why we're going to use them. The non-M E36 brakes are still 1" larger than the E30 4-lug garbage, so its still an upgrade. The stock 24" tall tires on the car now just barely clear the inner unibody structure at full lock, which they didn't even come close to doing before. If the shorter (275mm) Hoosiers can work like this, we'll keep it as-is. Otherwise we'll modify or build a LCA to correct for the E36 spindles in the E30 chassis. We came up with a game plan if this proves necessary, but we're going to move onto the rear 5-lug swap next, for now.
more below...
more below...
