your car is purty.
After a year of searching, an Alpineweiß story
wow, very clean car! :)
If you still need a 13 button OBC harness, I'm pretty sure I have one lying around.Comment
detail updates
My buddy found this at the junkyard for me.
(thanks Sal)
old fuse box lid
top
bottom
(note tab missing)
new lid
shop sticker
conitect sticker
3 intact tabs
little dirty on the bottom
all cleaned up in hott water, simple green, a tooth brush, and meguiars plastic X
mounted
a/c cap lines
I got some a/c cap lines.
I went to the junkyard and I cut off some ac lines and took the caps.
Since I don't have acces to a welder, I had my friend keith who works at Unique in Lake forest,
cut some circles to fit inside and have them fit flush then tig welded them in.
sanded them down then buffed them up.
what I started with
perfect sizes because they are actual a/c fittings
cutting some mild steel with a sheer
close enough for government work
pulse weld
rough
after sanding a little
after buffing them, they aren't perfect but I'm happy with them
done
Good idea on the ac lines. I just removed mine the other day and was trying to decide what I wanted to do. I think I will go the same route as you.
Cool strut bar, hadn't seen that...Originally posted by Simon SWhen a dream is a dream for too long - it becomes a fantasy..Comment
just a small detail but its all in the details
I can snap some more pictures of the brace.Comment
