project 7
  • 325Projectz
    • Jan 2005
    • 1956
    project 7
    so a buddy called me up one day, he was looking to give away this m30 which was still in his e32. he had no where to park the car i guess and told me i can have the motor if i take the whole car. i agreed, i was planning on parting the e32 and keeping the motor. yes! i got a free m30 for my 318. well i go look at the car, kind of beat up, but has potential... its mechanically sound, all new brakes, interior is shot to shit, paint is starting to fade in areas and it was hit in that drivers rear, just sheet metal damage though...
    under the hood, everything is sound except the a/c. all new hoses, all factory plastic covers, fuel line, etc...
    after kicking around the idea for a bit, i decided to keep the car and do a budget fix up. i starting looking into what its going to take to fix this thing up... its going to need pretty much all new interior, new cabs, tires, a/c belt, and one new a/c line. i don't know shit about this car! not quite as simple as a good ol' e30. time to learn...
    i'd like to keep this project under a few g's. i'm thinking $3k. the only thing that might cause this to go over budget is - the guy who gave me the car has a few factory and dinan turbo kits for an m30... hmmmmmmm... i might need to pick one up cause this thing is a boat. unfortunately, i didn't get any pictures of the car before i started pulling everything apart. oh well. i took some pictures of old parts though.
    the seats are trashed, the leather is super dry and feels like cardboard. not to mention they are torn up and stained.
    here are the old door panels with wood trim that warped.
    i needed a better base to start with, so i ebay'd some black panels, $190 shipped. they were in great shape once i got them, a month later... i could of left them as they were, but since they come apart easy why not wrap them? the wood trim on the new panels were in alright condition but they were starting to crack. we sanded the cracks out and wrapped them also.
    the suede parts of the door at back mounted, so it was super easy to wrap. the bottom of the doors panels have rolled edges and are glue in. since they are in good shape we left them alone. as you can see in the first door panel picture the lower b pillar cover was wrapped in black vinyl, which has the same grain pattern as the bottom of the panels.
    the door seals match the blue interior, but they are in great shape.
    here they are after a little bit of paint. remember, budget! painting them is fine. also, note the lower b pillar after a quick wrap.
    i decided to keep most of the trim pieces the original gray. if we paint the handles and seat belt trims, eventually the paint is going to wear and look like shit. plus it adds a bit of contrast.
    speaking of gray, here is the color material that the seats are going to be recovered in. i really like the grain and the feel of it. plus the trim will match.
    we pulled the headliner out, rear deck lid, sunroof liner and most other pieces that were covered in factory cloth and wrapped them. the headliner suede has a foam backing which took a while to order and get to the shop, but i guess the foam needs to be there for durability...
    the deck lid was one tricky mother to wrap. with the sun shade that's hot glued in (which we cut out and epoxied back in), the 3rd brake light area and lots of weird angles. we managed to cover it with one piece without wrinkles, nice! as you can see, we barely cut the suede large enough. the area around the brake light consumed a lot more material than we expected.
    here is the beat up blue (faded black?) dash. it will do for now, possibly forever unless i find a good deal on a black one in good-decent shape.
    i'll replace the center console, wood trim, lower dash and glove box door at a later date. they work for meow.
    so far, i'm in this thing about $1k. $100 for title transfer, emissions, 2 years registration, $300 6 months insurance, $190 for the panels, $150 for a/c part (receiver dryer, expansion valve, pressure sensor, etc...), $30 for a tank of gas to move this pig around and the rest in material. not bad.
    a big thanks to my buddy steve for helping out and letting me do this in his shop.
    stay tuned.
    91 m3
  • Eric Giles
    • 1068
    Still my favorite 7 series...I'm glad you are going to at least do a budget fix it up job than part it out. Keep up the good work!
    Eric Giles
    '20 M2 CS
    '04 M3
    '11 X5 35D
    '87 325is
    '91 325i Sport
    There are few things more expensive than a cheap BMW...
    • moving3e
      • Dec 2008
      • 268
      great work...not to often you see e32 projects. love what youve done with the interior
      • Joe318is
        • Sep 2005
        • 6451
        nice. Im having an 88 735 towed to my place this afternonn. I got the car fo FREE a year or so ago and my borther in law has been using it since.... until the trans gave out. I found a trans the other day at pick n pull for under $100. Not too sure what to do with the car after its fixed.
        Originally posted by vlad
        • Mtriple
          • 3139
          General Lee part deaux?
          Originally posted by Simon S
          • 325Projectz
            • Jan 2005
            • 1956
            got around to doing some more work on the 7... hopefully the interior will be done by the end of next week.
            here is the rear arm rest.
            since the dash was pretty beat up, steve made this insert which looks nice and hides most of the cracks in the dash. other cracks that were not covered by the insert were filled, sanded, and painted. the dash almost looks new.
            we cut the old seat up in sections, made patterns, sewed them up and started test fitting.
            rear seat cover is done, now its time to hog it on.
            here is the seat bottom installed. most of the wrinkles should come out within a few days...
            everything above this point was done on tuesday. i didn't make it to steve's shop last night, but he got a chance to finish up the back seat. i'm told its really comfy. here is a cell shot and you can kind of tell most of the wrinkles have cleared up.
            more to come.
            91 m3
            • N2MYE30
              • Oct 2007
              • 5536
              WOW!!! Nice work. I want to learn how to stich like that. Subscibed.
              COTM
              • Joe318is
                • Sep 2005
                • 6451
                my 7 went to the yard. pm'd you
                • Jalves619
                  • 596
                  I saw the thread title and my thoughts immediately wandered to lotus 7s so I was a little dissapointed, but that upholstery looks great. You don't happen to do that for a living do you?
                  • red325
                    • 961
                    Good work on those seats. That 7's lookin good
                    • george graves
                      • 20003
                      subscribed
                      Originally posted by Matt-B
                      • AbsorbantNut
                        Non faccio funzionare questa merda
                        • Jun 2010
                        • 2491
                        subscribed
                        this
                        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                        • E30Nova
                          • 1546
                          Agreed, when I first saw the pics and read the first post, I thought "dude, don't part that out, it's easily fixable!"
                          Glad you decided to fix it up. :up:
                          Matt
                          Matt
                          I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                          Originally posted by kronus
                          try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                          This is like a reverse build thread; it starts out nice and gets shitty.
                          • LuckyHenriksen
                            • Jun 2010
                            • 4244
                            Nice! Sweet project. I want free cars haha
                            Bahama Beige E23 Project
                            Bluebird Bus Conversion
                            New Oregon Trail
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              i don't do it for a living, but my friend who is helping me with this project does.
                              a couple more updates... the interior is getting really close to being done, for now.
                              front seat, with seat bottom done. getting ready to install the seat heater.
                              we managed to get the heating elements out of the old fabric without damaging them.
                              here is the heating element installed.
                              drivers seat is almost done. wrinkles will come out after a few days.
                              original seat back.
                              uncovered, ready to glue on the new vinyl.
                              after new vinyl. still need to sew up the seat back pocket.
                              and again, more to come.
                              91 m3
