'90 325i sedan. (bronzit content)
  • jaywood
    • Jul 2010
    • 4528
    Originally posted by bmwstephen
    how did u take off the bumper strips without breaking the tabs
    I used a flathead screwdriver to pry the tabs off from the back of the bumper
    It's impossible to not break a couple tabs. There are tabs that you can't see.
    You kind of have to push the tab out while you're pushing it to the side to get it to pop. After doing a couple it gets pretty easy, just takes some time.
    Originally posted by Mike The Bavarian
    the vinyl shadowline looks alot easier then painting it...I like what you've done so far
    • jaywood
      • Jul 2010
      • 4528
      Did a final layer of bondo (no pics) :(
      Needed some spot filler in areas
      All sanded and primed
      Getting painted
      Finished
      I'll probably finish the audio tomorrow, and might get started on the coilovers...updates soon!
      • Harry's E30
        • 643
        good work jaywood cant wait for the coils
        BUILD-http://www.r3vlimited.com/board/showthread.php?t=242728
        • robrez
          • Jul 2008
          • 3376
          Nice DIYing. I wouldn't have the attention to detail or patience to do half that stuff.
          January 2012 COTM
          • jaywood
            • Jul 2010
            • 4528
            Thanks guys :)
            Finished both sides of the trim. Pics will come when I get home from riding
            • jaywood
              • Jul 2010
              • 4528
              Got one side on
              Both sides on (sorry, it's dark out)
              • jaywood
                • Jul 2010
                • 4528
                Got a little update...put the front BC coilovers on today
                Gotta have the music
                Out
                Spring off
                Shock out (I had bilsteins in there?)
                Cut the strut housings and left 50mm
                Sanded all the paint off...got it ready to weld
                Welded and painted
                On
                Putting tie rod and control arm back in (had to use a jack to put pressure so I could tighten up the nuts)
                Both sides in and slightly adjusted...mad rake yo
                There's still a whole bunch of adjustment...right now the lip sits a little lower than the top of my iPhone. Spring rates are 10k/12k. I drove around the block to make sure everything felt right and it felt pretty nice...it handles soooo much better then stock
                Rears should be going in tomorrow if I get some time
                • M4DE30
                  • Jun 2010
                  • 309
                  Cant wait to see how this turns out. Subscribed!
                  KingB
                  • jaywood
                    • Jul 2010
                    • 4528
                    Got the rears on today
                    Chocked the front wheels and jacked it up
                    Removing sway bar links
                    At this point I had to drop the differential so the trailing arms could be pushed down, therefore letting the spring pop out.
                    Spring and shock out
                    Shock going in...didn't have a helper so I had to keep it held up somehow while I climbed in the trunk and tightened the bolts...so I used a wrench and a socket extension (would have used the bolt, but couldn't find it at the time)
                    Mom saw and had to get a picture...she helped me on the other shock :)
                    Springs getting ready to go in
                    Size difference???
                    Didn't get any pictures of the springs in :(
                    Aligning differential
                    Everything together
                    • jaywood
                      • Jul 2010
                      • 4528
                      Still too high ^^^^
                      I'll be adjusting it tomorrow and I'll try and get some day time shots...I'm tucking tire in the rear
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        you mean business
                        • kingston
                          • Jun 2010
                          • 2669
                          Man, this is coming along great! Nice work, man!
                          Originally posted by LJ851
                          kingston is the play by play announcer for this thread.
                          ‘Tis by the grace of God that my cars run!
                          Originally posted by unloadedak
                          #teamross
                          Siobhan's Build Thread - UPDATED!
                          • jaywood
                            • Jul 2010
                            • 4528
                            Thanks guys :)
                            Should be doing some audio stuff today when I get out of school.
                            • jaywood
                              • Jul 2010
                              • 4528
                              Finished the subwoofer box today
                              Cutting carpet to size
                              Getting wrapped
                              Done
                              Turned out pretty good...seams are hidden pretty well. I have a mesh cover that I'll be putting on it as well which looks good. It'll help protect the sub as well.
                              Went to the local audio shop after school today and used some of their keys to pop out my headunit. It should be getting wired in soon :)
                              The angle of the box is perfect to fit either in the trunk, or right behind the driver seat on the floor. Any suggestions?
                              How will a 12" sound in the trunk? My rear seat has no armrest, and the rear deck has no ports in it. I don't want to do any drilling on the deck/seat foam.
                              • Lencas
                                • Jan 2011
                                • 233
                                great choice on coilovers and nice job with subwoofer box ;)
                                why did you go with 10/12 springs ?
