Doin it again
    Originally posted by 328ijunkie View Post
    Swap your 1-3 and 4-6 o2 sensor. See if the misfires/codes follow
    No dice, it seems it's running out of fuel over 4K. I hooked up the pressure tester and started it and it went to 40 then as soon as I touched the throttle it jumped to exactly 50 and as I r3ved higher it started to drop down to 30 and the engine cuts out. Boggles me as it was running great a few days ago....
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
      Four months on and I'm assuming you got it fixed. Regulator or fuel pump?
      S52-Powered 1987
        Are you planning on boost if you put in arp head studs and a cometic gasket?
