Finally after 4 years of thinking about doing a S5X swap, it's come to fruition.
Over the past few months I have sourced the motor and all the parts needed for the swap and to convert the S52 to OBDI.
Dirty 96K S52 and all the parts (Oil Pan and pickup tube is going on tonight):
And while I get the motor ready, my local bodyshop guy is getting the E30 all pretty. There was some rust I wanted to get taken care of and while he was at it I thought it would be good to do a full exterior respray:
Shaved antenna hole:
S52 on the stand:
Degreased and block painted satin black:
OBDI Valve Cover powder coated wrinkle black:
Turner OBDII to OBDI Coolant tube adapter installed:
M20 getting pulled:
Parts List so far:
E36 S52 Engine with ZF320 Trans/Clutch/Flywheel
E34 Oil Pan, Dipstick with Tube, Pickup Tube and Oil Level Sensor
E36 Pickup Tube Gasket
24v Getrag 260 Trans Brace
OBD1 Conversion Kit: Intake manifold, fuel rail with injectors, engine wiring harness, red label 413 ECU, crank, knock & temp sensors, air temp sensor, manifold support brackets, AFM, throttle body, Vanos solenoid.
M50 OBD1 Valve Cover with Powdercoat
MPower OBD1 Valve Cover Plastic Shroud
Bremi OBDI Ignition Coils
S5X Alternator
E39 540 3.5" OBD1 MAF
3.5" to 3" MAF Adapter
TRM 3.2L 24Lb. M50 540 S52 Cams Lightweight 93 Oct Chip
Raceland OBD1 Longtube Euro S50 Rep Exhaust Headers
Turner OBD1 Coolant Pipe Adapter
Mishimoto SS Radiator
Spal Radiator Fan
Mishimoto Silicone E36 Radiator Hoses
OBD1 Spider Coolant Hose
OBD1 Wire Harness C101 Conversion
E30 ix Brake Booster with Master Cylinder
E28 535 Motor Mounts (Pair)
S52 Oil Pan Gasket
Oil pan sump gasket
Dipstick O ring
S50 Valve Cover Gasket
Valve Cover Grommets
Water Pump metal impeller
Vernet S52 Thermostat 88*
S52 Metal Thermostat Housing
Getrag 260 Pilot Bearing
Rear Crankshaft Oil Seal
E34 Throttle Cable
E30 Brown Top Coolant Sensor
E30 M42 ECU Mounting Bracket PN: 13 62 1 286 077
2.93 LSD
24Lb. Fuel Injectors
IE 22mm/19mm Sway Bar set
Swaybar Spacers to clear the Longtube Headers
EvoSport Underdrive Pulley
Upper Chain Tensioner
Samco Silicon Elbow for 3.5" MAF
M50 Intake Manifold Seals
Flywheel Bolts
Thermostat Housing Seal
Exhaust Manifold Stud and Nut Kit
Valve Stem Seals
6-29-11 edit: Finally picking it up from the paint shop tomorrow. Here's some pics:
S52 on the stand:
M20 getting pulled:
Parts List so far:
S5X Alternator
Spal Radiator Fan
S52 Oil Pan Gasket
Oil pan sump gasket
Dipstick O ring
E34 Throttle Cable
2.93 LSD
Flywheel Bolts
Valve Stem Seals
