1990 325i Delphin Coupe Project
  • hafa_adai
    • Apr 2011
    • 19
    Project car purchased on craigslist. I was told it was hit while parked. It had front end damage to the driver side. Even with the damage, the title was clean. Towed it home and started to evaluate the car.
    Considered parting it out because the rest of the car was intact and fairly clean.
    Decided to put a fender on it and see if things could be fixed.
    With a little tweaking it was close.
    It also needed a new control arm and front strut housing. Found at u-pull-it.
    Cleaned up the car and scrubbed the wheels.
    Eibach Springs and Bilstein shocks. Also found at u-pull-it FTW.
    Project Thread
  • airkhin
    • 593
    looks much much better! good work!
    • UDelaware30
      • Dec 2009
      • 336
      keep it up. great start
      • AbsorbantNut
        Non faccio funzionare questa merda
        • Jun 2010
        • 2491
        Seen this before? Did you post in another section a while ago?
        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
        • hafa_adai
          • Apr 2011
          • 19
          Yeah, just thought I'd start a proper project thread.
          Project Thread
          • drutt23
            • Feb 2011
            • 392
            Nice Project man. Good work with the body too. Keep it up!!
            1989 325i|1992 325i|And completely obsessed|:woowoo:
            sigpic BMW. The Ultimate Driving Machine.
            The Build...
            • hafa_adai
              • Apr 2011
              • 19
              Ordered some parts from BMA Parts. Amazingly they shipped free and arrived the next day. Wow!
              This car will be back on the road soon.
              Brembo Front & Rear brake rotors
              Pagid front brake pads
              Mintex Rear brake pads
              Front brake lines
              E-brake Shoes
              Mann Oil Filter
              Mahle Air Filter
              Mahle Fuel Filter
              NGK Spark plugs
              Timing Belt
              Replacement Exhaust Hanger
              Wipers
              Project Thread
              • TimKninja
                • 2131
                5 Speed swap planned anytime??? Great job repairing it and saving it!!!
                1985 325e M50TU(Sold)
                1991 318is Slicktop (Sold)
                1990 325is Brilliantrot S50/5 Lug Swapped.
                1992 525i Manual shitbox Winter Beater
                • hafa_adai
                  • Apr 2011
                  • 19
                  Decided to try to paint the blue door and fender to match the rest of the car. Got a pint of delphin paint at a local auto paint supplier. Used a $15 harbor freight HVLP spray gun.
                  The color is close enough for now. The main problem I had was the orange peel. Still need to wet sand and buff it out a little.
                  Took the car for a smog check and it failed just about every tailpipe category. In addition I've noticed the CAT has been rattling. Got a downpipe and cat from a forum member.
                  Removed the old stuff and noticed the flange on the old manifold was broken. With the new downpipe the car is much quieter now.
                  Have an M52 I purchased from Craigslist. Haven't decided if it's going into this car yet. We'll see....
                  Project Thread
                  • hafa_adai
                    • Apr 2011
                    • 19
                    Yes, 5 speed swap it on the list.
                    Project Thread
