My 325es Project
  • CW325
    • Jul 2011
    • 1434
    My 325es Project
    So ive been considering making a build thread so now i finally am. So heres the story...my uncle bought this car new in 86 and drove it around for a while but eventually ended up sitting in his garage so he eventually gave it to my other uncle . after years of abuse and a nice shady spot under a tree my uncle scored a deal on a mint 300e so now the e30 is mine. Heres what it looked like when i got it with 210k miles on it:
    not to bad on the outside but theres a lot of hidden rust more pictures to come....
  • CW325
    • Jul 2011
    • 1434
    So i thought an easy way to start would be to touch up the bumper trim
    since the car is an 86 plastic bumpers werent really an option so i decided to paint the whole bumper to match the body. also fixed up and put some primer on the hood
    eventually my parts arrived so i was able to install the new timing belt water pump and other various coolant hoses. also picked up a euro plate :D
    • ttrousdell
      • Nov 2009
      • 1770
      keep up the good work. So much potential to make these cars awesome even after they have experienced years of neglect.
      The Build:
      • CW325
        • Jul 2011
        • 1434
        when i got the car the suspension was crap. both front struts were shot and the stut housing completely rusted. i picked up some nicer housings from ttrousdell (thanks again!) and got to work on them. put new bilstien sports and bav auto performance springs in.
        got the car ready for the shiny new stuff :D
        than i found a slight problem...the sway bar bracket mount had completley rusted off. ill be getting a new crossmember but heres what it looks like now
        also i installed the rear springs and shocks
        eventually ill be getting all new bushings but the stock ones will stay for now
        the car is lowered about 1.5 inches all around and i think it looks pretty good
        • MR E30 325is
          • Dec 2008
          • 3300
          Excellent work!
          Glad you will recover it and bring it back to life!
          My previous build (currently E30-less)
          http://www.r3vlimited.com/board/showthread.php?t=170390
          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
          • CW325
            • Jul 2011
            • 1434
            i ordered an AFM adaptor and a cone filter in order to make my own cold air intake. I know i wont really get any power gains but i was looking for something to do and i thought it might give the car a cooler sound
            My uncle helped me cut and bend this bracket to hold the afm out of some metal i picked up for $8
            i also had to pick up some new nuts since the stock ones with the built in washers did not clear the afm adaptor
            Before:
            after
            and here it is finally finished (notice the bracket now painted black):
            • CW325
              • Jul 2011
              • 1434
              at my cars old home the street often flooded...and the car too so i decided it might be a good idea to rip out the smelly old ripped up carpet.
              Heres how it looked right after the seats came out:
              and here it is finally out, i cheaped out around the heater core because i didnt want to mess up anything. there were piles of dirt under where all the rips where:
              surprisingly other than some surface rust this is all i found, a nasty hole behind the drivers side seat. i still need to find a way to patch it up once i have access to a welder. all other rust was sanded down and painted to prevent further spread of it.:
              • CW325
                • Jul 2011
                • 1434
                i recently removed both the valve cover and intake manifold. Both will be getting a fresh coat of paint along with new gaskets. i also ripped out the thermostat and thermostat housing so i will be getting a new one shortly. make sure to plug the holes on the head with paper towels to prevent anything from getting inside
                Engine without valve cover and intake:
                cleaning the valve cover, im using carb cleaner:
                i used engine degreaser for the intake manifold, make sure you flush out the intake when your done because you dont want any leftover getting in your engine:
                Before painting make sure all openings are completely taped up along with all the parts that the hoses attach to . You dont want any overspray on the inside or where the gaskets go. for anyone who cares ill be posting picture once the paint is done and everything is installed.
                • ttrousdell
                  • Nov 2009
                  • 1770
                  I can help you with that rust. i know it sounds a little ghetto but use gasoline for cleaning that kinda shit. works wonders. 7 dollars for carb cleaner or 4 dollars for gallon of gas. saves money
                  The Build:
                  • CW325
                    • Jul 2011
                    • 1434
                    or get some "high quality" cleaner for a 1.23 from walmart :D
                    • beybedba
                      • 517
                      i envy your ES Valence...
                      • CW325
                        • Jul 2011
                        • 1434
                        really? thats funny, i always thought the late model ones looked nicer!
                        • CW325
                          • Jul 2011
                          • 1434
                          im holding off on all engine work for now because im considering pulling it and doing a complete reseal once i know if i have acces to a engine lift. I thought that since i wont be working on the engine, now would be a good time to remove all the sound dampener in the trunk and inside the car.
                          i started by prying up the trunk tar with just a screw driver
                          also removed all interior sound dampener
                          i than painted all newly exposed metal in the interior and trunk to prevent any rust from forming
                          overall it was a lot easier than i thought and i removed close to 70lbs of weight, enough to actually slightly raise the rear of the car so i will soon be removing my spring pads to try and even it out a bit. thanks for looking, more updates to come...
                          • MaxBell
                            • 1391
                            Looking good dude! How hard was removing the carpet?
                            REMEMBER: Be safe and have fun is Rule Number 1.
                            The Epic Unbuild of Clint Eastwood
                            • CW325
                              • Jul 2011
                              • 1434
                              it wasnt that bad, once you take out the seats and center console its pretty self explanatory, i just cut around the the center console by the dash instead of completely removing the entire dashboard. i probably lost a few pounds of sweat too ;)
