24v swap plus other goodies
  • thepoloplaya
    • 81
    The plan was originally to boost the m20, but ive decided to start on another platform, so im going m50 that will see boost later in the future.
    Drivetrain
    M50b25 non vanos
    255/245 cams
    10lb flywheel
    kevlar clutch
    ACL race bearings
    Mahle rings
    Dicktator Standalone
    Polyurethane motor mounts
    Polyurethane tranny mounts
    zf tranny
    3.91 LSD (considering a 3.73)
    Suspension
    M3 CABs
    E90 M3 spring caps
    21mm front sway
    all new ball joints, etc.
    ATE pads and discs
    205/40/17 front
    225/45/17 rear
    Bodywork
    roll rear fenders
    shaved engine bay
    fix all imperfections
    new undercoating
    The idea is to build a really clean (emphasis on clean), daily driveable, decent handling, quick (not fast at the moment) e30.
    transporting the motor (mk1 parts getter
    motor before rebuild
    shaving of engine bay
    strut assemblies (before rebuild)
    and the parts collection
    more work done today
    cut out battery tray
    made stencil
    cut out of steel
    test fit
    I finished the battery tray delete today but dont have any good pics of it.
    im using polyster filler on the bay, got a bit of work done on that
    hopefully ill be able to finish up and get the bay primed tommorow
  • F34R
    sLaughter
    • 12376
    All these filled bays being done, will look nice and clean =)
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • thepoloplaya
      • 81
      Got some primer on the bay today, the right side turned out ok, but im not happy with it
      still need to finish up the left side, but I did get some primer on it
      and how she sits now (sad sight)
      Wont be able to do any more work on her till Tuesday, hopefully will be able to get her to the bodyshop for paint next week.
      • Vtec?lol
        • Dec 2009
        • 3278
        Keep up the good work.
        I think I may shave my bay!
        • thepoloplaya
          • 81
          At the moment, im not sure if I like the look of the joints to the the strut tower, I did use polyster filler in very thin amounts, but im still concerned about cracking. I went out and bought polyurethane seam sealer that Im gonna use on the left hand side, then compare the two and decide what I want to do
          • thepoloplaya
            • 81
            • nrubenstein
              • 3148
              3.91 or 3.73 aren't going to give you much top end with a ZF diff. As in, you'll run fifth out in moments.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • thepoloplaya
                • 81
                The Zf tranny im running is out of a e30 320i. The ones here did not come with the getrag 250. I was running the same box and diff setup in my m20 and I had no complaints about it. I do however have a getrag 260 that I may consider swapping in as im not sure how the zf will last under boost.
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  wow nice thread.
                  especially when you see the post count ratio.
                  amazing car can't wait to see it all buttoned up.
                  keep it up! :D
                  • thepoloplaya
                    • 81
                    Thanks, im usually on r3v everyday for quite a decent amount of time, but I dont feel the need to post much.
                    I got more work done today and am now happy with the right side, time to finish the left side, also cleaned up the wheel wells today and applied new undercoating. will post pics later
                    • SA E30
                      • 1248
                      Slaap Stad ;) Nice work there, pls tell me you're considering binning the mt2 though.
                      • thepoloplaya
                        • 81
                        Thanks Stevin. I am a fan of the mtech2 so thats staying, although I am removing the rear spoiler.
                        Some updates. finished the shaving in the bay and primered it up. Tommorow the suspension will be put back together.
                        Also cleaned up the wheel wheels.
                        • thepoloplaya
                          • 81
                          engine bay put back together, going for paint this weekend.
                          back on the ground
                          gotta LOVE clean engine parts!
                          • RLloyd
                            • Jun 2011
                            • 43
                            Very nice, what is the 255 cam out of?
                            • thepoloplaya
                              • 81
                              thanks, the cams are out of a m50b20nv.
