The 600 dollar 87' 325is: air ride!
  • Rc 415
    • Jun 2011
    • 723
    #361
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
    • bsturman92
      • Sep 2012
      • 282
      #362
      absolutely ridiculous your the fu$%&$ man
      • Rc 415
        • Jun 2011
        • 723
        #363
        1987 Delphin 325IS
        Build Thread
        1993 alpine 2 325IC
        • MattAvino
          • Jan 2011
          • 2147
          #364
          Sounds incredible
          E30 buildy things
          http://www.r3vlimited.com/board/showthread.php?t=195286
          • Rc 415
            • Jun 2011
            • 723
            #365
            1987 Delphin 325IS
            Build Thread
            1993 alpine 2 325IC
            • Denny
              • Jan 2010
              • 822
              #366
              The stance..the engine...the look....the sound!! Man I love this car...
              Denny
              ___________
              1990 BMW red 325IC M30B35 all stock Girlfriends ride
              1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
              Blogs:
              http://bmw325e30.blogspot.com/ (restoration)
              http://bmw325e30turbo.blogspot.com (Twincharge M20)
              http://bmw325e30m62b44.blogspot.ca/
              • Rc 415
                • Jun 2011
                • 723
                #367
                Found this old vid yesterday
                1987 Delphin 325IS
                Build Thread
                1993 alpine 2 325IC
                • Rc 415
                  • Jun 2011
                  • 723
                  #368
                  So last few weeks since I got the car back from paint, I've but everything back on except the door trim. The car has been sitting on jack stands, taking my time ironing out the kinks.
                  First was the driveshaft flange tapping the top of the subframe over 4k rpm. Dropped the driveshaft and filed the edge of the flange just a little, problem solved.
                  Second, passenger side downpipe was leaking at the 3 bolt flange, installed new smaller bolts so I can actually get a socket around them, no more exhaust leak!
                  Third, and what I've been putting off most is the drivers side downpipe hitting the steering shaft on right turns, locking up the steering wheel.
                  My roommate had the day off work and decided to start cutting it up to notch it, and he made the patch too. Welding tomorrow and reinstalling.
                  Lastly, I have a power steering leak that needs to be addressed, other than that I still haven't finished putting the wiring in loom for the standalone fuse/relay center and that's it!
                  1987 Delphin 325IS
                  Build Thread
                  1993 alpine 2 325IC
                  • Rc 415
                    • Jun 2011
                    • 723
                    #369
                    Patch welded in
                    1987 Delphin 325IS
                    Build Thread
                    1993 alpine 2 325IC
                    • jakeb
                      • 1909
                      #370
                      Good idea on the steering/exhaust clearance.
                      www.classicdaily.net
                      1970 m42 swapped 2002
                      1985 LS1/T56 Swapped e28 (557e)
                      www.blunttech.com - For all your parts needs
                      Follow me on Instagram for constant build updates @classicdaily
                      https://www.facebook.com/ClassicDailyLLC
                      • Denny
                        • Jan 2010
                        • 822
                        #371
                        Denny
                        ___________
                        Blogs:
                        • Rc 415
                          • Jun 2011
                          • 723
                          #372
                          1987 Delphin 325IS
                          Build Thread
                          1993 alpine 2 325IC
                          • LSM3
                            • May 2012
                            • 340
                            #373
                            So you ran your exhaust between the steering shaft and the D/S rail?
                            • Rc 415
                              • Jun 2011
                              • 723
                              #374
                              Nope steering shaft and engine block
                              1987 Delphin 325IS
                              Build Thread
                              1993 alpine 2 325IC
                              • Rc 415
                                • Jun 2011
                                • 723
                                #375
                                1987 Delphin 325IS
                                Build Thread
                                1993 alpine 2 325IC
