Is it getting spark or fuel? I know mine didn't start cause I goofed up and hooked fuel lines up backwards. Since your car sat id start with a compression and fuel pressure test. As Well to see if its getting spark. Good luck hopefully you get her to fire up.
Alpina B6 3.5 Turbo Tribute
Originally posted by ThatOneEuroE30 View PostIs it getting spark or fuel? I know mine didn't start cause I goofed up and hooked fuel lines up backwards. Since your car sat id start with a compression and fuel pressure test. As Well to see if its getting spark. Good luck hopefully you get her to fire up.
Frank and I were checking out the Alpina big brake kits that are on picnic table. One of the Alpina BBK is not in pic. They are on a e30.
DSC04694 by Raul Salinas, on Flickr
DSC04696 by Raul Salinas, on FlickrProjects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Originally posted by e30m3s54turbo View PostWhen I pulled the engine wire harness off motor I noticed one of the power wires was not bolted to power. My buddy Frank came by to check out engine wire harness to see it was working connections and ecu. After a couple hours we got power to ignition and relays. Next week will play around with fuel injection.
Ah i see.
Hey where did you get that Alpina fabric ;)
Originally posted by TimeMachinE30 View PostYou have more BBKs than E30s.
What is the next E30? An MK? Another ACS?
I found a silver 1989 325i coupe. I am trying to buy it. It will be Hartge H27 or H35?
Ah, I need to get mine finished.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Originally posted by e30m3s54turbo View PostFrank bought from your friend in Europe.
Any more up dates on your project?
I know he called me and I set up the order. Glad it got there with no issues.
It is alive. It started up. I have some small issues to address.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Originally posted by e30m3s54turbo View PostIt is alive. It started up. I have some small issues to address.
Originally posted by ThatOneEuroE30 View PostNice! What was the culprit of the no start?
I was good day hear it run!!!Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Originally posted by e30m3s54turbo View PostFuel lines were crossed. Bad ground connections.......
Originally posted by Bimmer_man View PostHey raul, so happy to hear that that thing is finally running. Any chance of a vido of the alpina doing alpina things?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Raul, it's been a while since I sold you that Alpina gas tank all those years ago. Very happy to see you still getting work done!!My previous build (currently E30-less)
http://www.r3vlimited.com/board/showthread.php?t=170390
A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
Originally posted by MR E30 325is View PostRaul, it's been a while since I sold you that Alpina gas tank all those years ago. Very happy to see you still getting work done!!
I been a few years when you and I met. The Alpina extended is bolted in and works!
Here is a short vid. It sound very noisy with out tuning and 3" exhaust...
M4H04707 by Raul Salinas, on FlickrProjects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
