'91 318is, 16V swap.
  • jaywood
    • Jul 2010
    • 4528
    #151
    Sorry if I missed it, but what are you doing for the booster? Manual brakes, remote setup?
    • FunfGan
      • Jan 2011
      • 4958
      #152
      Believe I said it before but no worries. I'm doing a remote set-up. I'm using an e34 booster/ ms/ linkage. It will be like that which people do for m60/s60 swaps except the 5.0 is thinner, so it doesn't look like the linkage needs to be modified much, if any at all. I'm also running an abs delete, so I'm going to split one of the outputs on the master cylinder, and keep the old hard lines for the brakes.
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • jaywood
        • Jul 2010
        • 4528
        #153
        Pics pics pics? Lots?
        • FunfGan
          • Jan 2011
          • 4958
          #154
          Once I get the engine in correctly I can start actually hard mounting the set-up, I'll be sure to post lots of pics!
          Go here be happy!
          • jaywood
            • Jul 2010
            • 4528
            #155
            So did you get the CD of the whole swap process from e30v8?
            Did the motor mounts end up needing modification?
            • FunfGan
              • Jan 2011
              • 4958
              #156
              I did, the cd is insanely helpful. And yes, mounted needed modification, unless theres something I'm not seeing. If you saw the pics a few pages back, thats in the only holes on the mounts that the engine even goes in.
              Go here be happy!
              • jaywood
                • Jul 2010
                • 4528
                #157
                Are you going to be making new motor mounts? Or maybe slotting the holes if that's possible??
                What are you doing for the tranny? Did you get the mount from e30v8?
                • FunfGan
                  • Jan 2011
                  • 4958
                  #158
                  Going to do some measurements and drill a new hole, and maybe reweld the old hole. May also need to chop off part of the end to clear the steering column. Its annoying, but they were cheap so i'm not that upset. Still much better than building my own mounts.
                  And no, I just ordered a replacement mount for the trans and am currently modifying the old transmission mount to work with it. Wont take long, just need the rest of the drivetrain mounted to really do measurements.
                  Go here be happy!
                  • jaywood
                    • Jul 2010
                    • 4528
                    #159
                    Interesting.
                    Definitely take lots of pictures! I'm sure I'm not the only one who wants to see this get done ;)
                    • jaywood
                      • Jul 2010
                      • 4528
                      #160
                      One more q: can you keep heater?
                        • 37827
                        #161
                        Usually project threads have pictures of the project's progress... Just sayin'
                        Classic BMW Specialists
                        Santa Clarita, CA
                        www.BimmerHeads.com
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          #162
                          and progress ;)
                          Originally posted by Wh33lhop
                          VANOS: sometimes you just need to go full retard.
                          • FunfGan
                            • Jan 2011
                            • 4958
                            #163
                            There is a way. Am I going to take my time to do that? No.
                            I only bump when I have progress, its only ever bumped if somebody has questions. I'm terribly sorry that I'm taking my time to help other considering the swap.
                            Go here be happy!
                            • jaywood
                              • Jul 2010
                              • 4528
                              #164
                              When are you planning on having it done?!!
                              • jekaio
                                • Jun 2008
                                • 89
                                #165
                                what wheels are those?
