'91 318is, 16V swap.
  • FunfGan
    • Jan 2011
    • 4958
    #526
    And your're like 15 now, right?
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • Exodus_2pt0
      • 5943
      #527
      Originally posted by JasonC
      Good luck with your adventure! And hope you dont find this when you deside to open it up!!!
      That was my Firehawk when i bought it! I still have the block since its the original matching#'s to the car. But pretty obvious it needs some machine work if i'm ever to use it again.
      Funny thing... We just picked up a 95 Z28 that looked like that on the inside.
      No E30 Club
      • eurotrash
        • May 2007
        • 768
        #528
        Fuck mystery oil Alittle atf in the cylinders will work wonders.
        • shEck3lls0
          • Jan 2011
          • 1154
          #529
          We pulled the heads.... cylinders were fine. Just a little sludge. Heads were good too. Speaking on behalf of Stuart.... I think he'll have a picture later.... This is a very annoying mystery.
          1989 Alpine 325is 2dr m50 swapped
          Build Thread:
          Current ongoing build. Check it out!
          1991 318is 4dr rallycross
          Rallycross Build Thread.
          1991 Alpine 318is coupe - sold
          • Exodus_2pt0
            • 5943
            #530
            Better check the bearings in the bottom end.
            This is an honest question as well, are you attempting to turn it over by the starter or by the crank bolt?
            No E30 Club
            • shEck3lls0
              • Jan 2011
              • 1154
              #531
              Crank bolt.... got on it enough to tighten it even more... just isnt budging... I personally think the motor is fine since it turned out of the car. I think its the clutch or flywheel.... Who knows though. We are tired of going on a wild goose chase and are pulling the motor this weekend.
              Build Thread:
              • Exodus_2pt0
                • 5943
                #532
                Way better than guessing. :up:
                No E30 Club
                • FunfGan
                  • Jan 2011
                  • 4958
                  #533
                  Yep. Pulling it saturday, I'll investigate more thoroughly once its out, and I have the car up and running. Rings are good, pistons are good, head gasket looks brand new(said it was rebuilt before it was crashed, and I believe him). So its gotta be bottom end stuff, and I'm not in the situation to do an engine rebuild at this point in time. Heres a pic of the block with the heads off,
                  Go here be happy!
                  • Exodus_2pt0
                    • 5943
                    #534
                    Did you put that oil in there after you removed the head? If that was already in there when you removed the heads, then you problem was hydro-lock.
                    If that is the case, you should turn each cylinder to TDC and measure it's depth in the cylinder wall. Hydro-lock is how rods get bent.
                    No E30 Club
                    • BenjaminButtton
                      • May 2012
                      • 275
                      #535
                      This. That's wwaaayyy too much oil in the cylinders to run.
                      Early models do it better.
                      '86 Cosmos Sedan LS1
                      • FunfGan
                        • Jan 2011
                        • 4958
                        #536
                        Was already in there though. I think the issue may have been the clutch/ flywheel though.
                        Go here be happy!
                        • Exodus_2pt0
                          • 5943
                          #537
                          If that oil was already in there, then I can promise you that was your problem.
                          Try turning the engine over now without the heads installed.
                          No E30 Club
                          • FunfGan
                            • Jan 2011
                            • 4958
                            #538
                            Already did so, no change :(
                            Go here be happy!
                            • shEck3lls0
                              • Jan 2011
                              • 1154
                              #539
                              Even if the oil was in there, with the spark plugs out, it would have turned over.
                              Build Thread:
                              • Exodus_2pt0
                                • 5943
                                #540
                                Yea I was thinking about that this morning.
                                Carry on. But for future reference, don't put that much oil in there. ;-)
                                No E30 Club
