'91 318is, 16V swap.
  • TimKninja
    • 2131
    #646
    Yalls a lazy ass mofo.
    Ive been waiting for a burnout video for to damn long
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • FunfGan
      • Jan 2011
      • 4958
      #647
      Originally posted by Exodus_2pt0
      Ditching the remote mount? Probably a wise move.
      Yeah. It'd be $200 just for the manual conversion plate from Massive, and I really don't like how Matt says to attach the clutch pedal. I just don't like it being bolted to the firewall. Here's the box I'm getting
      Originally posted by jalopi
      Goddamn that thing is loud... you weren't kidding - not really surprised though, considering the exhaust setup. Can't wait to see this beast in action!
      Hey man! And yep yep, quite loud :D
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • jalopi
        • 2370
        #648
        That pedal setup does look nice, but damn is it pricey. So is the wilwood master you have going to work with that pedal box? Or are mods gonna be necessary?
        • FunfGan
          • Jan 2011
          • 4958
          #649
          I dont think so, I was going to call them and see if they had any idea. If they do, I was going to just order a custom setup with just the brake master on there. Unfortunately, I just don't think it will. So I'll probably end up just trying to sell the pedal and mc, or just keep it for my mid engine mini truck build.
          And yeah, it's pricey but I've decided it's time I just save up and get a quality piece, instead of multiple things I don't need.
          Go here be happy!
          • 325ix
            • Aug 2009
            • 7783
            #650
            You should just route the exhaust out the fenders!
            • FunfGan
              • Jan 2011
              • 4958
              #651
              I've considered it. But I think I'm just going to do an insert muffler and continue out the sides of the valance. I'm really worried after seeing the number of flames it shoots under no load, how many it'll shoot under load hahah.
              Go here be happy!
              • lambo
                Captain Scene Points
                • 10953
                #652
                Originally posted by FunfGan
                And I was joking about that It has no frame damage.
                Ban.
                • dnick
                  • Apr 2011
                  • 1377
                  #653
                  Originally posted by lambo
                  ban.
                  ban hammer
                  • ak-
                    • 12422
                    #654
                    Gj!
                    1991 325iS turbo
                    • eurotrash
                      • May 2007
                      • 768
                      #655
                      Which carb are you running? Nvrmind even if your running an edelbrock now your gonna wind up having to go to a holley so ill just tell you how to tune that.
                      Start by setting the floats. There are 2 sight holes in the side of the bowls. You want those to just trickle when the car is bumped. You adjust using the needle and seat adjusters at the top of either bowl. Clock wise brings the float down counter brings it up. You'll also want to set ur idle air mixure (the screws on the metering blocks between the main body and the bowls) turn them in all the way then back them out 1.5 turns. From there adjust for a nice smooth idle and set ur final idle rpm using the throttle stop screw on the throttle.
                      Make sure your accelerator pumps are set right also by bringing the adjuster screw down to just touch the pump arm.
                      Use stock jets and pump cams and read up on the net on how to read plugs, get an afr gauge or just bring it to a shop with a dyno to set your jetting.
                      I also suggest getting some thumb screws for the bowls and the reusable bowl gaskets. This is where reading plugs can come in handy. U can have a 20hp swing based on weather conditions and the carb being jetted properly for the conditions.
                      Of course your also going to want wedged floats and jet extensions so your not affected by fuel slosh(this is what will kill u with the edelbrock) u can also go as far as to trim down the throttle horn.
                      • eurotrash
                        • May 2007
                        • 768
                        #656
                        Of course all of this is after you make sure your as close to 7psi fuel pressure as possible.
                        • FunfGan
                          • Jan 2011
                          • 4958
                          #657
                          Yep! I got it idling and running well, thanks for the info!
                          Go here be happy!
                          • Exodus_2pt0
                            • 5943
                            #658
                            Burnout vid?
                            No E30 Club
                            • eurotrash
                              • May 2007
                              • 768
                              #659
                              No prob i was possitive you used black magic and a hammer to tune a carb when i first got into this.
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #660
                                It was pure stupidity/ taking bad advice on my part.
                                Anyway, it shoots 1-2 foot flames as soon as you let off the throttle above like, 2500rpm. Thought ya'll should know.
                                Go here be happy!
