So don't shoot first... Think about it for a minute. Lots of LS1 swaps happening so we know the engine will fit.
The C4 'vette has a drop out IFS suspension mounts/engine cradle.
Engine bay or frame rail comparison:
C4 = 28.125" across inside
E30 = 27.625" across inside
About 0.5" difference or 1/4" per side - the C4 K-member could be sectioned or the E30 frame rails could be modified
C4 IFS hub to hub width is around 61.5". 84-87 is narrower than later C4 by about 1".
The rear suspension is also a drop out, complete unit. 62" wide hub to hub with discs on.
Track width:
C4 track width is 59.6"/60.4" F/R.
E30 track width is 55.4"/55.7" F/R.
Box flares would be appropriate.
The C4 engine does sit too far back in the engine cradle. However, we know the engine fits in the E30, so this should be a matter of finding or modifying the right pan that works with the proper engine location. Motor mounts shouldn't be a huge undertaking. There are adapter plates available to use the stock mounts that move the engine 3" forward. Custom motor mounts are readily available or can be fabricated for short money.
Granted there would be much fabrication involved. This is not about common sense. It's an idea that might work.
Too crazy or just right? For a "streetfighter" style build?
Salad shooters bolt on!!!!
Track width:
