My '75 2002 Sleeper
  • tinkwithanr
    • Jun 2010
    • 377
    #316
    Thanks for the tip. I have been using my MAP torch to Preheat for now. Ideally I'd love to be able to find an old oven or something like that, it would be a lot more precise. But for now the torch is getting the job done. It definitely makes a difference.
    Tinker Engineering - 2014
    Mica - 2000 BMW 323i - The one that started it all
    Fiona - 1975 BMW 2002 - The Definition of Project Creep
    Heidi - 1988 BMW M5 - The piece of BMW history
    Silvia - 2013 Subaru WRX - Stock, for now
    • evandael
      • Oct 2009
      • 2881
      #317
      very inventive work with the ITB adaptation, i always admire how simple you make it seem!
      • 325ix
        • Aug 2009
        • 7783
        #318
        I can't wait until I have the time/space/money to do something like this. The car looks awesome, I can't wait to see it rolling down the road.
        I also really want to learn to tig weld. I learned most of the other types but, never got to learn that one.
        • e30_neverstock
          • Nov 2011
          • 283
          #319
          those itb's are looking great. i need to do the same thing for my 2002, but i need a little more practice with my tig welder.
          • JoeMadoo
            • 936
            #320
            These last 22 pages just blew my mind. Amazing things going on here.
            '86 E30
            '05 E53 X5
            '72 Firebird
            '10 Prius
            '03 Tundra
            • SkiFree
              • Jun 2011
              • 2766
              #321
              Glad to see you got the parts.....
              Quick question, what is the i.d. on the mouth of the itbs?
              ADAMS Autosport
              • tinkwithanr
                • Jun 2010
                • 377
                #322
                They are 38mm. I just finished porting the manifold, and it seemed to blend very well overall. The other huge plus is 1.5" ~ 38mm, so I could use standard tubing sizes for the runners and plenum parts.
                • tinkwithanr
                  • Jun 2010
                  • 377
                  #323
                  I decided to clean up the throttle bodies since they were pretty dirty when I got them. Can you guess which one is which??
                  5 more throttle later:
                  Here's a close up of the extensions I welded on the linkage tabs. Works great.
                  Then I worked on blending the modified intake manifold. This is how it looked when I started:
                  And after a couple minutes with a die grinder it changed to this:
                  And here is the same port with my spare gutted throttle body in place. I'm very happy with the overall taper and size, though I still need to fine tune a couple of areas. But I'm going to wait to finish them until I match the manifold to the head, which still needs to be ported as well.
                  And here they are bolted in place in the engine bay. The nice thing with this setup is it doesn't get in the way of the stock fuel rail, pressure regulator, and thermostat housing. My original S54 setup had some clearance issues:
                  Then I had to reposition the dipstick tube. If you look at the above pictures, you can see the stock position puts it right between the first and second cylinder ports. With my plans for a plenum this would definitely get in the way. Luckily my largest bead roller die was the perfect diameter to the dipstick tube, so I was able to avoid pinching the tube at the bends. After a few carefully placed bends this is what I ended up with.
                  This new position should sit right between the intake plenum and the upper radiator hose.
                  Thanks for looking!
                  • A Sucked Orange
                    • 707
                    #324
                    :hitler:
                    • tinkwithanr
                      • Jun 2010
                      • 377
                      #325
                      Small update from today. Didn't have a lot of time to put into her but I managed to get the steering linkage figured out. I only have pictures of the 'finished' product (I use that term loosely), but I basically just took the stock E30 linkage from my parts car and shorted all the sections of it so that the universal joints were closer together. Then I shortened the stock steering column.
                      I also needed to notch the firewall a bit so that the angle between the sections was small enough that the universal joints wouldn't bind. The lower one was fine, but the upper joint was very close.
                      I also need to add another support bearing to the middle section of the linkage. In the stock setup, the steering column didn't have any universal joints, it just ran straight to the steering box. Because of that the stock '02 steering column only has one point of support for the shaft itself. But now with the extra joint in the linkage the shaft has a bit of play, which the extra support bearing will take care of.
                      • red_e30
                        • Dec 2010
                        • 242
                        #326
                        Nice
                        my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
                        • semaj4712
                          • Mar 2012
                          • 3069
                          #327
                          I want to be just like u!!!
                          29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
                          72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
                          Gewerkschaft der Polizei Sticker/Clings For Sale $8
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #328
                            Originally posted by tinkwithanr
                            Looks like you're missing the plate that goes in between the engine block and trans?
                            1989 BMW 325i SOLD
                            1998 BMW Estoril Blue e36 M3/4/5 SOLD
                            1987 BMW 325 (The Piece) SOLD
                            1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
                            • Roysneon
                              • 4505
                              #329
                              Quite sure that's his mock up engine.
                              Originally posted by mbonanni
                              I am a pursit now.
                              • tinkwithanr
                                • Jun 2010
                                • 377
                                #330
                                Yup, I just threw the trans on there for making up the engine and trans mounts.
