Thanks for the tip. I have been using my MAP torch to Preheat for now. Ideally I'd love to be able to find an old oven or something like that, it would be a lot more precise. But for now the torch is getting the job done. It definitely makes a difference.
My '75 2002 Sleeper
those itb's are looking great. i need to do the same thing for my 2002, but i need a little more practice with my tig welder.Comment
Glad to see you got the parts.....
Quick question, what is the i.d. on the mouth of the itbs?Comment
They are 38mm. I just finished porting the manifold, and it seemed to blend very well overall. The other huge plus is 1.5" ~ 38mm, so I could use standard tubing sizes for the runners and plenum parts.Comment
I decided to clean up the throttle bodies since they were pretty dirty when I got them. Can you guess which one is which??
5 more throttle later:
Here's a close up of the extensions I welded on the linkage tabs. Works great.
Then I worked on blending the modified intake manifold. This is how it looked when I started:
And after a couple minutes with a die grinder it changed to this:
And here is the same port with my spare gutted throttle body in place. I'm very happy with the overall taper and size, though I still need to fine tune a couple of areas. But I'm going to wait to finish them until I match the manifold to the head, which still needs to be ported as well.
And here they are bolted in place in the engine bay. The nice thing with this setup is it doesn't get in the way of the stock fuel rail, pressure regulator, and thermostat housing. My original S54 setup had some clearance issues:
Then I had to reposition the dipstick tube. If you look at the above pictures, you can see the stock position puts it right between the first and second cylinder ports. With my plans for a plenum this would definitely get in the way. Luckily my largest bead roller die was the perfect diameter to the dipstick tube, so I was able to avoid pinching the tube at the bends. After a few carefully placed bends this is what I ended up with.
This new position should sit right between the intake plenum and the upper radiator hose.
Thanks for looking!Comment
Small update from today. Didn't have a lot of time to put into her but I managed to get the steering linkage figured out. I only have pictures of the 'finished' product (I use that term loosely), but I basically just took the stock E30 linkage from my parts car and shorted all the sections of it so that the universal joints were closer together. Then I shortened the stock steering column.
I also needed to notch the firewall a bit so that the angle between the sections was small enough that the universal joints wouldn't bind. The lower one was fine, but the upper joint was very close.
I also need to add another support bearing to the middle section of the linkage. In the stock setup, the steering column didn't have any universal joints, it just ran straight to the steering box. Because of that the stock '02 steering column only has one point of support for the shaft itself. But now with the extra joint in the linkage the shaft has a bit of play, which the extra support bearing will take care of.Comment
I want to be just like u!!!
29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
Gewerkschaft der Polizei Sticker/Clings For Sale $8Comment
1989 BMW 325i SOLD
1998 BMW Estoril Blue e36 M3/4/5 SOLD
1987 BMW 325 (The Piece) SOLD
1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207Comment
Quite sure that's his mock up engine.For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
Yup, I just threw the trans on there for making up the engine and trans mounts.Comment
