Sadly my ebay addiction continues. This is only part of the newer direction:
More to come.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all Fiona - 1975 BMW 2002 - The Definition of Project Creep Heidi - 1988 BMW M5 - The piece of BMW history Silvia - 2013 Subaru WRX - Stock, for now
Rear:
4-Piston Forged Calipers
300mm (11.75") x 32mm (1.25") vented 2-piece rotors
Retains Stock Hand Brake
The front and rear will share the same rotor disc, so maintenance/replacement will be easy. The brake bias is kept at the proper ratio due to the difference in the piston area for the 6-pot front and 4-pot rear calipers. It can then be fine tuned with the balance bar pedal setup and by changing out the master cylinders if need be.
i wish i was related to you.. this shit is godly.. truely amazed... i sat here at work the last 2 hrs going over this entire thread... i give you a HUGE thumbs up man! very impressive shit
Well 28 pages later this has been one awesome build thread. I am def tuned in for the long haul. Where in Ohio are you located? If you are close I would certainly come out and lend a hand if you needed it for anything.
Originally posted by Denny
OMG!! BANG!!:twisted: what an evil build...
:up:
Originally posted by deutschman
So do bigger brakes mean there will be more POWER!?
Eventually... The base power plant hasn't changed. Just other parts of it.
Thanks, I'll keep that in mind. The shop in in Springfield, where are you located?
