My '75 2002 Sleeper
  • Kevinxkrazy
    • Sep 2011
    • 531
    #106
    damn looks a bit chewed up. but we've all seen what you can do and admire your ambition.
    1984 Eta
    1987 Bagged
    1988 I
    1995 MX5
    1998 C70T5M
    2002 CL600
    • ACHTUNG
      • May 2005
      • 2397
      #107
      That there's a big 'ol project. You're doing a great job!
      1989 US E30 Cammed S52
      Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
      • e30shmobberr
        • 1934
        #108
        You sir are going to make one hell of a 2002. great work! im looking forward to seeing the final result!
        Patrick - IG:niicknac
        RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
        • tinkwithanr
          • Jun 2010
          • 377
          #109
          Thanks guys. Glad you have faith in me, I'm gonna need it!
          While I don't have any pics of the blasting progress (I just finished replacing the last of the stock parts on the sand blaster besides the pot itself, grrr), I figured I could at least share some of the recent parts purchases.
          First I broke down and picked up some Blare Spot-Weld cutters. A bit late considering i already removed the nose panel, but I'm sure I'll need it for other parts here shortly. These are particularly slick in that they have a spring loaded centering pin that retracts as you drill. To start, you 'punch' the metal in the center of the spot weld, and then drill until your through the first layer of metal. Much better than the 0.25" drill bit I was using before lol.
          Next up my e36 rear diff cover came in. I decided to use this because of the dual rear mounting ears compared to the single ear on the e30 diff. Also, this will let me swap in one of Rogue Engineering's fancy finned diff covers down the line (http://www.rogueengineering.com/rogue/DC/DC_E36.html).
          Ignore my 1 minute bead blasting job, I just wanted to knock the grime off.
          Should bolt right up with some slight modifiations.
          Last but definitely not least was the start of my fuel system. For the past month I have been trying to decide what route to take with my fuel supply. I could keep the stock tank with an e30 318 fuel pump, but that would probably be well undersized for my final power goals. Which means I would have to replace it in the near future, not something I wanted to do. Then there is also the issue of how 'safe' the stock fuel tank is, along with the lack of internal baffling and a single pick up. This would lead me to need to use a surge tank setup, which only adds complexity to the fuel delivery system. This lead me to look into fuel cells, but most of the ones I came across were unsatisfactory. Pretty much all of them used foam for their internal baffling (if they had any at all), which degrades over time. It also doesn't stand up to e85 fuel very well at all, and since I'm planning to use that under boost, none of those tanks would work.
          Then I came across the Aeromotive line of Stealth Fuel Cells. Initially I thought they were very overpriced, until I realized that they came with an internal prefilter, pump, and fuel sender all in one package. But by far the best aspect for me was that they use an internal baffling system to keep fuel around the pickup of the pump at all times. This was key for me, because I plan to drive the car very hard, so starvation is a big concern. The specs of my tank in particular are:
          15 Gallons (20x18x10) - fits in the stock location for the most part (slight modification required
          Internal A1000 Pump - rated for up to 1000hp in forced induction applications (or closer to 600hp in e85, which gives me enough room to work with)
          GM 90 Ohm fuel sender - While not the 3-73 ohm range of the stock sender, it's close enough that I can make it work with some simple circuitry.
          Shiny:
          -10AN Outlet from the pump, that's a lotta fuel lol
          Here you can see some of the baffling. The vertical tube on the left is the return line, it dumps back into the center of the tank which is also where the pickup for the pump is, separated by a small wall. If the fuel level gets low in the tank, the return will dump straight back into the baffle, keeping the remaining fuel by the pickup. The baffling also helps keep the pickup submerged during high side-loads (think long, high speed sweeping corners). You can see the pick up and the prefilter on the right side of the picture.
          :woot:
          Tinker Engineering - 2014
          Mica - 2000 BMW 323i - The one that started it all
          Fiona - 1975 BMW 2002 - The Definition of Project Creep
          Heidi - 1988 BMW M5 - The piece of BMW history
          Silvia - 2013 Subaru WRX - Stock, for now
          • e30polak
            • 6136
            #110
            You sir have some serious skills! :bow:
            This car will be epic when finished, keep up the hard work!!! :up:
            INSTAGRAM: @UNDR8D_EMPIRE
            • goarmy
              • Nov 2011
              • 622
              #111
              2002
              great job so far
              • tinkwithanr
                • Jun 2010
                • 377
                #112
                Thanks for the compliment! Hopefully the car will live up to all the hype lol.
                Originally posted by goarmy
                great job so far
                Thanks man!
                • drumad
                  • Aug 2009
                  • 1700
                  #113
                  Obviously this isnt your first time doing a build (if it is, bravo).
                  You got any links to other work you've done?
                  This is quite amazing.
                  2008 335i - n54b30
                  1991 318i - m52b28
                  1994 fzj80 - LAND CRUSHER
                  • tinkwithanr
                    • Jun 2010
                    • 377
                    #114
                    Believe it or not this is my first build, pretty much learning as I go.
                    • drumad
                      • Aug 2009
                      • 1700
                      #115
                      Well, I suck then. I'm also poor. Proceed with the build sir!
                      2008 335i - n54b30
                      1991 318i - m52b28
                      • FredK
                        • 14759
                        #116
                        Yeah, the spotweld cutter will be way easier to use, and will disturb the least amount of metal underneath.
                        Every time this thread gets bumped it's exciting to see all the progress!
                        • mikeedler
                          • 6707
                          #117
                          Just got done reading the complete thread (never saw it before). Great work-- Seems like you are in a similar situation with the rust I am in with my 55 Bel Air.
                          Keep it coming!
                          • Kevinxkrazy
                            • Sep 2011
                            • 531
                            #118
                            that's exactly what i was thinking lol
                            1984 Eta
                            1987 Bagged
                            1988 I
                            1995 MX5
                            1998 C70T5M
                            2002 CL600
                            • Kevinxkrazy
                              • Sep 2011
                              • 531
                              #119
                              any updates?
                              1984 Eta
                              1987 Bagged
                              1988 I
                              1995 MX5
                              1998 C70T5M
                              2002 CL600
                              • GDA
                                • 446
                                #120
                                Awesome work and skills!
                                Great to see you refurb tools and then start using it on the project. Sub'd for future updates.
