TheTacoMan's build, Turbo'd, mflare'd.
Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/ -
Is this your first time with megasquirt? Seems as if megasquirt is much more sensitive than the stock ecu.
Cps did fix my problem.
yeap my first time with MSII. Its definitly looking like the same problem you had with the CPS. How do you adjust it closer? I dont see anywhere to make adjutements..?Denny
___________
Blogs:
http://bmw325e30m62b44.blogspot.ca/Comment
There are two bolts, one is kind of hard to get to but doable. Loosen the two bolts and just move it closer to the teeth.
Ok cool will check this out... thanks manDenny
___________
Blogs:
Finally got a dyno at 7psi, Keep in mind that it was 1st gear(2.43 with a final 3.73). It closer to a second gear in a 5 speed.
Also the afr is a little weird in this photo, not sure why.
Its about 220whp. Also Traction is not possible in the rain. Sooooo much fun
I would ignore the bottom piece of the graph, its completely inaccurate. It reads in Kpa and is very off, says I would be at 28psi according to the program.
I decided against a new paint job and am getting ready to order m3 flairs or kamtors flairs and some large 17s, The cars paint is old and peeling everywhere and is extremely brittle. So I am getting the m3 flairs( and skirts,bumpers), just going to rivet on the rear q panels and call it a day. Should look decent, after college Ill get it professionally painted and ill have a garage to keep it away from the elements.
The uniformity of one black fender has been pissing me off.
On another note, im pretty low for just h&r race.
Got an actual walboro fuel pump wired in. Dont buy ebay fuel pumps! Should go without saying but I was dumb enough. Car got alot faster.Last edited by TheTacoMan; 05-17-2013, 05:20 PM.
Denny
___________
Blogs:
