Gonna do the same route for my car. Just rivet it on. Thank you!
Sent from my SCH-I545 using Tapatalk 2
Planning to rivet them as well, its not worth molding the more I looked into it, It will be like a an over fender. Molding would be ton of effort for something that isnt perfect to begin with.
Got some fitting done today, one fender on in about hour and half of fitting with two people. Ill be making them pretty but fitting for now. Hoping to tackle rear and the other fender tomorrow.
Couple things I noticed, the fiberglass isnt perfect but the mounting is pretty good and the way it fits once sorting out door clearance issues is good. I should be able to flair it out a bit more then camber plates, should be more clearance than I had before. I need to add a bit of material to some spots and adjust the hood and it should be good to go.
