TheTacoMan's build, Turbo'd, mflare'd.
  • TheTacoMan
    • Nov 2011
    • 2308
    Got a mustang oxygen sensor wired up, and a narrowband gauge to see so general air fuel ratios. I have to say I was starving fuel on top and now it revs much more freely. Seems like it pulls so much better.
    • TheTacoMan
      • Nov 2011
      • 2308
      Getting parts and everything lined up and ordered for the stroker and 5 speed. Also have 19lb injectors, millerchip and maf sensor all lined up as well.
      It should be a stroker within the next 2 weeks.
      • TheTacoMan
        • Nov 2011
        • 2308
        Got my tires on today. 225/50/15 on trm 15x8s. More pictures to come.
        • TheTacoMan
          • Nov 2011
          • 2308
          • e30Villain
            • Jun 2012
            • 540
            Nice wheels. Great color!
            Can't wait to see some videos of the stroker. I am thinking about stroking my eta as well.
            87 ETA | Hibernating
            • TheTacoMan
              • Nov 2011
              • 2308
              I have the head here, just made a 190$ order to pelican parts. Should be a stroker this weekend.
              • camip
                • Nov 2011
                • 1253
                How are you liking that rim and tire set up. I'm about to order a set.
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  Havent driven it yet, getting ready to take it apart. Ask kamotors he has had the same set for much much longer.
                  • camip
                    • Nov 2011
                    • 1253
                    Will do. Where are you located in Nevada I just spent two days in Pahrump and now checking out Vegas for a few days.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      Up in Reno, about 8 hrs away.
                      So parts should be here thursday.
                      • camip
                        • Nov 2011
                        • 1253
                        I was in reno last summer floating down the river.
                        • TheTacoMan
                          • Nov 2011
                          • 2308
                          Its a fun thing to do, good when its hot.
                          On a side note my car go lower from the new wheels, my driveway is now my enemy :|
                          • kamotors
                            • Nov 2007
                            • 7102
                            225/50s dropped my car about .25"
                            7speedshop.com
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              So, i have the top end off, everything look perfect except the cooling system. Very corroded with the ports on the throttle body closed off. Tons of rust and gross coolant. Looks like it may be well over 15yrs old. Havent got into the water pump yet, that will be tomorrow :crazy:
                              • BavarianAddict06
                                • Sep 2011
                                • 315
                                Just did a stroker on a buddy of mine's car. Big difference. did you happen to do a comp test and leak down test before hand? dont make the same mistake i did. turned out the block was toast now spitting out blue smoke like a mofo. good luck with the stroker!
                                1987 528i Royalblau
