TheTacoMan's build, Turbo'd, mflare'd.
Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/ -
Wideband is wired, boost gauge is ready. Need some small stuff, like clamps, plugs, and some more vacuum lines etc. A buddy of mine who's running basically the same setup on a 2.7i hit full boost with this turbo at 2k. This is going to be insane.
Here's a pic of his car, its still in need of some stuff.
Car is now running, but it wont rev above 4k. It has a revlimiter, even with megsquirt set to no revlimited. Car runs really well, just has a damn revlimiter so low. Im trying to fix it right meow.
This typically is the CPS when there is too much gap, try loosening and keeping it as close to the trigger wheel as possible and tighten back up and see if it helps.Comment
Update please :)
Last time I had a 4k rpm cutout was because it was so rich that it basically did the same thing as a rev limiter.Denny
___________
Blogs:
http://bmw325e30m62b44.blogspot.ca/Comment
