TheTacoMan's build, Turbo'd, mflare'd.
    Originally posted by TheTacoMan View Post
    Mocked up the rest of the piping, looks like everything is going to work well.:D
    Getting very close...looking good:D
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
      Wideband is wired, boost gauge is ready. Need some small stuff, like clamps, plugs, and some more vacuum lines etc. A buddy of mine who's running basically the same setup on a 2.7i hit full boost with this turbo at 2k. This is going to be insane.
      Here's a pic of his car, its still in need of some stuff.
        What kind of turbo are you running?
          Ebay special :D. Turbo is very well put together and it actually a high quality piece. Has balance marks too.
          It was either this or a used holset which I i don't trust used turbos.
          If it breaks oh well, no loss it was cheap.
            I ran an eBay turbo on my last build and it worked great for a year +
            What size is it?
              What size is it?
              I believe it is a .63 a/r, it has a 2.75in inlet with a 2.5 outlet. Im going to go bigger, but for now this is fine.
                Nice. Good luck! Keep us updated!
                  Car is now running, but it wont rev above 4k. It has a revlimiter, even with megsquirt set to no revlimited. Car runs really well, just has a damn revlimiter so low. Im trying to fix it right meow.
                    This typically is the CPS when there is too much gap, try loosening and keeping it as close to the trigger wheel as possible and tighten back up and see if it helps.
                    My M20 Frankenbuild(s)
                    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                      Ill try it
                        Update please :)
                        Last time I had a 4k rpm cutout was because it was so rich that it basically did the same thing as a rev limiter.
                        Denny
                        ___________
                        Blogs:
                          yeah taco man we need an update
                            not running rich, its at high 12afr when it cuts out, no rich or lean spikes, running a decent tune. physically bounces like a revlimiter.
                            7speedshop.com
                              Sup bum,
                              Ill have time to trouble shoot it Friday.
                                fix it naow, wooman
                                7speedshop.com
