Calling all E30 Gurus!
  • Farintosh
    • Mar 2012
    • 38
    Hello all,
    Ran into some trouble with my E30 and am completely stumped, any help would be greatly appreciated.
    First some background info. I bought my first E30 325iC and changed the timing belt 2 months ago as a precaution. All was well until just last week when I started to hear a thumping on my way home then a grinding. Took it all apart to find the camshaft gear had worked and the dowel pin was no long snug. I changed both parts and now there is no grinding or whining but the entire engine still bounces significantly when the car idles. If necessary I can post a video of the engine running. I adjusted the valves during the timing belt change and they were fine, so I don't think that's the problem. Wondering if its something as simple as new spark plugs, but I'd love a second opinion before I open it all up again.
    Tempted to take the car into a professional and get there opinion, anyone come to mind? I live just north of Markham. Is the dealership viable or should I find a private shop/individual?
    Thanks for your time!
    Geoff
  • EDirtyZ
    • Jun 2012
    • 243
    Seafoam it and check your mounts.
    • Farintosh
      • Mar 2012
      • 38
      Got some help, 5th cylinder wasn't firing, electrical problem. Valves may have gotten loose inside as well. We'll see.
      • 325ix
        • Aug 2009
        • 7783
        Check for vacuum leaks. Hoses, gaskets, everything.
        • EDirtyZ
          • Jun 2012
          • 243
          I don't see how a cylinder not firing causes clunking? Are your valves twisted?
          • bmwguy325is
            • May 2011
            • 1263
            Maybe you slipped a tooth or two on the belt
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • dirty30
              • 3048
              Check the injector harness wiring, I've seen a few that had corrosion in the plugs or were slightly melted.
              • Farintosh
                • Mar 2012
                • 38
                Alright lots to check, I'll let everyone know how it goes when I get a chance. First I'll find where I'm losing the electrical current then I plan to check the valve train to see if everything is in good running order. Thanks for all the suggestions, I'll certainly try all of them if need be.
                • Farintosh
                  • Mar 2012
                  • 38
                  Here's a video: http://www.youtube.com/watch?v=uhs32...ature=youtu.be
