<<< Iz aluminium, no?
★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
Just curious. How fast were you going when you hit the boulder? And are you going to add extra metal to the pan for extra precaution?88 d21 draggin pavement
89 dirty30 kissin earth
Im just here to learn new things and meet new people.Comment
30mph at the most. Probably closer to 20-25. Nope, I've never had an issue except for these two rather exceptional instances. I am interested in seeing what can be done to my broken pan. Maybe something a bit more custom and a lot stronger.
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
Front subframe bolt snapped in the frame. Neat. Literally the last bolt before throwing the wheels back on and going for a drive hahahaha......
It's slightly depressing nothing has happened to this car recently. Been desperately trying to get into a truck and get in on the overland life.
DSC_5731 by Phillip Keefe, on Flickr
A couple small things have changed, though...
I changed out my failing DDM tuning shit HID's for a set from dinanm3atl. The color temperature was supposed to be the same (4300k) but the new ones look much more OEM, which is a good thing!
Before:
After:
Zip tie engineering at it's finest.
I also have some winter tires on order. 185/70 Michelin X-Ice Xi3's to go on my stock weaves. Figured it was only fitting to get a stud kit to further the rally look. Also, thanks for the rad key chain MH.
