★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
Added yellow vinyl to my high beams. I like it! For the time being, anyways.
Before
lol weight removal
Boom. Turns out the passenger side headlight had a previously broken adjuster tab that had been repaired but failed. So, I had to epoxy it back together again...
Annnddd all done!
Lights on
Oh yeah, here's longcat lol
Knocking front or back? Strut collars? Dead shock?
Contingent on your dampers you're most likely just bottoming out the shock. Bump stops or no.
Knocking is coming from the front. The driver's side shock is blown but the noise is coming from the right as well. I'm sure I'm not bottoming out. Strut collars are also tight.
There are some videos and stuff in this thread, if you're interested!
Have you contacted Komi or GC for a replacement strut insert yet?
Yeah, I've talked to Mark. Only problems are that my strut inserts are an older style so I need to buy a new one for the right side as well as get a replacement for the left. Also, I have no garage to work and not a lot of time to work on my car... blehhhhh
Hmm, with shortened housings don't you just unbolt the three nuts at the top (camber plate) and you can pull it out from under the fender? I can do that on mine with stock housings, so swapping struts is a breeze. I wouldn't worry about time or space too much.
And before people try to take this the wrong way, I'm only asking in case you didn't realize how easy it is :)
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
