I'm back (E30 M3 content)
  • Court M3
    • Jan 2004
    • 6713
    Nice pickup!
    Continuous For Sale Thread
    323i s50
    • Eric535
      • Jul 2012
      • 186
      so you got this eh? nice pick man, looking forward to seeing it come together
      • pwagon717
        • Jun 2007
        • 1197
        Yea, I picked it up. Sourcing all the parts. The 2002 is on eBay right now, so that will fund the project. Stay tune.
        _________
        Rep Savannah Crew
        • 328ijunkie
          • May 2007
          • 3961
          Hawt! ;)
          Check Us out on Facebook
          Full Product Line Tuning
          • pwagon717
            • Jun 2007
            • 1197
            Update with no pictures:
            Drove up to Knoxville to meet with RobertK and pick up the S52 and trans. Sending out the wiring harness, and ECU to Technica. The plan is stay OBD-2 with the engine. Just dropped the engine and car off to Dan (Hamlerda). This is going to be a well documented project with pics.
            _________
            Rep Savannah Crew
            • freeride53
              • 11972
              Ohh lehhh do ettt.
              Yes. I love e30 m3 restos.
              1983 Peugeot 505 STI
              1992 Volvo 240 Wagon
              • catuned
                • Jun 2011
                • 2324
                Here we go!
                Work We Do
                CAtuned Feedback Page|FB CAtuned Page
                http://www.catuned.com
                • hamlerda
                  • Dec 2004
                  • 12
                  • hamlerda
                    • Dec 2004
                    • 12
                    • hamlerda
                      • Dec 2004
                      • 12
                      • hamlerda
                        • Dec 2004
                        • 12
                        The List:
                        Exhaust: Consider emissions regulations within your state.
                        Engine harness modification (part provided by Dan)
                        DME Reflash (or consider the OBD1 route)
                        M50 Conversion kit
                        Radiator (I'll check to see what I have)
                        Coolant Temp Switch: 80/88
                        Coolant Hoses
                        Clutch: OEM Sachs recommended
                        Flywheel: (I've had excellent results with the F1 Racing Chromoly)
                        Valve cover gasket
                        Oil Pan Gasket
                        Timing Chain tension (personal spare seen in pics)
                        Spark Plugs
                        Coils (?)
                        Throttle body w/TPS? (I'll need to double check you parts pin)
                        Transmission cross member? (I'll need to double check you parts pin)
                        Short Shifter? (I recommend Auto Solutions)
                        Transmission Bolts: (Dan)
                        Driveshaft
                        A/C compressor w/associated lines?
                        Consumables :
                        Engine Oil
                        Transmission Oil
                        Diff Oil
                        Brake Fluid
                        Coolant or Water wetter (depending on intended use)
                        Belts
                        Exhaust Gasket ?
                        Fuel Filter
                        Preventative Maintenance:
                        Safety wire the oil pump nut?
                        Dr. Vanos
                        Driveshaft Center Bearing
                        • pwagon717
                          • Jun 2007
                          • 1197
                          Originally posted by hamlerda
                          The List:
                          Exhaust: Consider emissions regulations within your state. Going with E30polak setup: Flo-pro into a vibrant
                          Engine harness modification (part provided by Dan) Need to send out
                          DME Reflash (or consider the OBD1 route) Need to send out
                          M50 Conversion kit Is this kit worth the money
                          Radiator (I'll check to see what I have) Brand new rad bought
                          Coolant Temp Switch: 80/88 Bimmerworld kit on the way
                          Coolant Hoses Researching best ones
                          Valve cover gasket Blunt tech ordered
                          Oil Pan Gasket Blunt tech ordered
                          Timing Chain tension (personal spare seen in pics) Need part #
                          Spark Plugs NGK ordered from Blunt
                          Coils (?)
                          Transmission cross member? (I'll need to double check you parts pin) In trunk
                          Short Shifter? (I recommend Auto Solutions) Called and left a message on Friday
                          Driveshaft Bought a 97 M3 4 bolt on the way
                          Consumables :
                          Engine Oil
                          Transmission Oil
                          Diff Oil
                          Brake Fluid
                          Belts
                          Exhaust Gasket ?
                          Fuel Filter
                          Safety wire the oil pump nut? Bimmerworld on the way
                          Dr. Vanos
                          Blunttech ordered
                          _________
                          Rep Savannah Crew
                          • F34R
                            sLaughter
                            • 12385
                            Done right, this will be really great!
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • RobertK
                              Kicked cancer's ASS.
                              • Jun 2005
                              • 5864
                              After all the same issues I've had with my rebuilt S50 I kinda wish I had kept this S52. It was a strong motor minus the crappy spark plugs the PO had put in it.
                              • pwagon717
                                • Jun 2007
                                • 1197
                                And finally done with it...exhaust and seats left
                                _________
                                Rep Savannah Crew
