Hello, I have been on R3V for awhile now. Bought my first daily e30 about 2 weeks ago. I bought it off another member. I had to trailer the car home, and I used this forum to get the car back on the road again. Well here are some pictures then I will tell you the problems I need help with yet again.
Pictures:
When I got the car:
After replacing:
Spark plugs
Plug wires
Cap/Rotor
CPS (dont think it was needed,but oh well)
Then the car was running good.
The car had already a Dinan chip, m50 injectors, and a cat back.
Then I switched the interior to all black leather, with sport seats.
After interior I purchased some e38 Style 5's 16x8's with a 195/50-16 Dunlop's. Using 20mm adapters.
The car came with "Ground Control" coils with eibach springs.
So me and my buddy cut off the spring perch and welded on a nice metal ring for them coil to sit on. Doing this to go a bit lower.
And thats where it is today. My head gasket is leaking oil so I'm ordering a a top end gasket set in the morning.
MY PROBLEMS: So yesterday I drove my car on a 100 mile round trip and on the end of the way to my destination my car started running poorly in the lower RPM's. I suspected spark. So when we got back to my house I hooked up a timing light to check just for a quick thing and it showed perfect spark. I then thought fuel, wishful thinking I had a fuel filter laying around so I put the new one in. That still didn't fix it. Now I'm thinking maybe injectors? Maybe go back to stock ones and ditch the chip so I can run 87 oct fuel again. What do you guys think?
And there is a high pitch whine coming from the engine bay while driving.. can decide what it might be.
Also tomorrow I will be installing a IS front lip and maybe order some 15mm adapters for the front so I can go a little bit lower.
Pictures:
When I got the car:
After replacing:
Spark plugs
Plug wires
Cap/Rotor
