E30 M3 touring with S62 power
  • DaveG
    • Nov 2011
    • 40
    #31
    Got a few hours at the car today between the Olympics and everything.
    Still turning out to be way better than expected, I hope my M3 turns out to be as good when I go at it someday.
    Engine out
    Rear out
    Bulkhead rust free even around where the loom goes into the car.
    Just finish stripping the interior now and the fun part of removing the loom :D
    Not an awful lot new to report, got most of stripping finished and got it mounted onto the spit. Floor pan looks really good with the fuel tank and everything removed, hope to get a start on some of the rust repairs next weekend.
    A few pics of how it stands now
    Just realised that if this all goes wrong it will be on a big public forum for everyone to see ��
    Anyway back to the task in hand
    Inner sunroof skin removed
    Bottom skin was fairly bad
    Then remove cassette
    Drill out spot welds around opening
    Drill spot welds at b pillar
    Then cut supports at the 4 corners being carefull not to cut through the roof skin
    Use heat gun to soften sealer and remove cassette
    Before
    After
    Would really suit you leins, nearly 2" more head room��
    The start of some rust between cassette and roof skin even though it looked perfect
    Made up a brace to go in front of the sunroof opening and some filler strips for around the sunroof panel
    Time for another bit of an update
    Filler strips tacked in
    Sunroof panel welded in
    Started on some of the rust repairs
    rust behind seam sealer
    Cut out rust
    Make Template
    Cut some sheet and beat into shape
    Weld
    Template again
    Weld
    From underneath
    Ground down and primed
    Other side
    Was a bit of rust between engine bay a bulkhead which turned out to be a good bit when ground back
    Cut out the rust again
    From inside
    From wheelarch
    Templates
    Weld in first piece
    Inside
    Next
    Grind
    • asuj158
      • Nov 2008
      • 1206
      #32
      legit
      • evandael
        • Oct 2009
        • 2881
        #33
        Mmm I want some rotisserie in my life..
        excited to see more!
        • Luis325
          • 3847
          #34
          more?
          1986 "C2 2.7 Alpina" Sedan
          1987 325ic Black Vert
          • PeturW
            • 24
            #35
            Subscribed!
            Diamond schwarz, BMW E28 518i - M30 swap in progress
            Schwarz Mica, 1994 BMW 325i Touring - M50B25 Vanos - 3.73 LSD - Design Edition.
            Brilliantrot, 1989 BMW 325i Touring - M50B25NV - Drifter - Welded diff, sold
            Alpinewiess II, BMW 318i - M10 - euro pre-face, sold
            • oliver.r
              • Mar 2012
              • 3839
              #36
              Vlad aint got shit on this!
              Subd'
              • GunMetalGrey
                • Dec 2010
                • 1499
                #37
                This will be a beautiful build, I appreciate you attention to detail on something so awesome!
                • DaveG
                  • Nov 2011
                  • 40
                  #38
                  Thanks, will get the rest of the updates up later.
                  • DaveG
                    • Nov 2011
                    • 40
                    #39
                    Stripped all the sealer off the bottom of the car. There were a few bits of rust hiding even though the sealer was perfect.
                    Inner sill
                    Rear pocket
                    Cut
                    Template
                    Weld
                    Grind
                    Front jacking point didn't look too bad till I took it off
                    So back to the usual
                    Cut
                    Template
                    Weld
                    Grind
                    Template
                    Weld
                    Jacking point
                    Like new again
                    Crash damage at the rear was a bit worse than I had thought. See where the floor was creased and the panel is pushed in near the top mounting point on the spit. Going to have to straighten it all out and probably put a new back panel on it.
                    Converted the cluster to alpina spec
                    KM cluster from eBay.de for KM speedo, ltr fuel gauge and ltr/100km fuel consumption
                    Original cluster from car, note mileage, fair bit of going
                    Dismantle cluster
                    Remove needles
                    And faces
                    Remove tach to access econo needle which can't be removed from spindle
                    Remove needles from spindles
                    Give needles a rub with 400 paper and give a coat of primer
                    Paint
                    Mpg v km
                    Needles back on, km faces and alpina decals applied.
                    Before
                    After
                    The one I was trying to copy
                    I'm happy with the finished job, the alpina decals are a little larger than the original ones but you would only notice it if you saw them together.
                    • DaveG
                      • Nov 2011
                      • 40
                      #40
                      I had these wings from a shell I got from Ben . They're not great to be honest but they will do for mocking up for the moment, priced 2 new rear quarters from bmw at 680 euro for the pair so will probably go that way for the sake of it. Also the M3 had preface lift pockets so the new rear quarters would also be an advantage for fitting the rear bumper.
                      Cut out the best bit of the quarter and put on the shell
                      Difference in height of facelift against prefacelift arch
                      Going to add a nice both of width to the car
                      Front arch
                      Side skirt attached for positioning
                      Will have to do some cutting into the bodywork now and see what's the best way to go. I don't want to just slap the quarters on top as was done on the one in the US. I want to be able to rust proof everything so will be cutting away the original quarters.
                      Here is the engine that's destined for the engine bay
                      01 M5 S62 , 400 bhp , should move a 1250 kg e30 on nicely .
                      Will need to make some custom manifolds for this and also get the ecu flashed to get rid of the Can Bus stuff.
                      Other plans are to probably use a Z3M back axle and M3 evo front struts.
                      Might get the shell chemically dipped and E Coated to make a lifelong job of it also when going this far.
                      Should keep me busy for a while ��
                      Ok another bit of an update,
                      Made up some new mounts for the spit that allow me to work on the back panel and put on and off the back bumper for lining things up
                      Made a start on the rear quarter, bit by bit to get an idea of the best way of proceeding.
                      Rear quarter back on to see how things are,
                      The main problem is that the standard inner arch comes down and out to the arch lip whereas the m3 inner arch comes out all the way before coming down parallel with the outer quarter. This leaves lots of gaps between the inner arch and the quarter . This could be just filled with new steel but that would leave a lot less clearance for the tyre.
                      Here you can see the difference
                      And also see how far the quarter is away from the inner arch at the filler
                      And at the front of the arch
                      I have ordered an M3 inner arch to see how I can get on with fitting that also.
                      The M3 front bumper is held on with a different carrier than the others
                      Standard car
                      Only problem is that only the right hand side one is available from bmw so I will have to make one for the other side or modify one . A lot of e30 parts have gone NLA in the last while which is a concern.
                      Made a couple of back bumper mounts
                      There is a big difference in the pre and facelift pockets, the facelift ones are wider and are in the way for fitting the M3 bumper.
                      Prefacelift/M3
                      Facelift
                      So lots of fun ahead of me :D
                      • GK-E30M3
                        • Apr 2008
                        • 816
                        #41
                        Crazy but looks like you know what your up to
                        • evandael
                          • Oct 2009
                          • 2881
                          #42
                          this jacking plate.. did you fab it or is it a BMW part? i searched realoem but it only came up with a 'jack fixture' which sits on the frame rails.
                          • xAZxE30x
                            • 1241
                            #43
                            wow! this is going to be so amazing. Lots of tourings seem to be rocking the m3 panels. I may have missed it but what is the color going to be?
                            • wannaBMthree
                              • Apr 2007
                              • 601
                              #44
                              nice fucking work. Thanks for sharing.
                              • DaveG
                                • Nov 2011
                                • 40
                                #45
                                I made up a new jacking point myself, didn't check with bmw
                                Grey. Silver grey,fjord,granite or maybe Ferrari silver stone Grigio. Not sure yet
                                Thanks
